Error "OSError: 118"
nebenzahl
Post by nebenzahl » Thu Jul 04, 2019 2:38 pm
I need to run a URL and it is giving this error "Error" OSError: 118 " when I execute the command" s.connect (addr) "
Below my code:
import sys
from machine import UART, Pin
import socket
startgprs = Pin (26, Pin.OUT)
ledpower = Pin (19, Pin.OUT)
ledgprs = Pin (23, Pin.OUT)
ledgps = Pin (18, Pin.OUT)
led = Pin (22, Pin.OUT)
phone = UART (1, baudrate = 9200, rx = 16, tx = 17, timeout = 10)
answer = ""
led (0)
ledgprs (0)
ledgps (0)
ledpower (1)
def executes (with):
    res = (phone.read ())
    phone.write (b '% s \ r'% (with))
    time.sleep (0.5)
    return res
def command (with):
    return
def connectgprs ():
    startgprs (1)
    time.sleep (3)
    startgprs (0)
def connect gps ():
    time.sleep (3)
    command ('AT + CGNSPWR = 1')
def http_get (host, path):
    print (host)
    print (path)
    addr = socket.getaddrinfo (host, 80) [0] [- 1]
    s = socket.socket ()
    s.connect (addr)
    s.send (bytes ('GET /% s HTTP / 1.0 \ r \ nHost:% \ path \ host \' utf8 '))
        date = s.recv (100)
        if data:
            print (str (data, 'utf8'), end = '')
            break
http_get ('x.x.x.x', 'gps_recebedados.php')
I believe this error is because I can not get on the internet.
Because I'm using an ESP32 and an ev80 SIM808.
I can send SMS through this SIM808 module. But I was not sure if I still surf the internet with him.
In C ++ I can execute this URL.
How can I test this output for the internet.
I'm not going to use wifi in this project.
Thank you!
nebenzahl
Re: Error "OSError: 118"
Post by nebenzahl » Thu Jul 04, 2019 3:24 pm
I added this snippet of code:
gsm=UART(1,rx=16, tx=17, timeout=1000, baudrate=9600)
ppp=network.PPP(gsm)
ppp.active(True)
when I execute these commands, the result is this:
>>> print(ppp.active())
True
>>> print(ppp.status())
None
>>> print(ppp.isconnected())
False
>>> print(ppp.ifconfig())
('0.0.0.0', '0.0.0.0', '255.255.255.255', '0.0.0.0')
how can I make my esp32 arrive on the internet through a GPRS connection?
Post by Roberthh » Thu Jul 04, 2019 4:09 pm
Testing this feature is still on my To-Do-List. But as far as I understood it, one has to establish a conection first with AT-Commands and then attach the ppp channel.
nebenzahl
Post by nebenzahl » Thu Jul 04, 2019 5:15 pm
How do I do this?
As I already said, I can communicate with the SIM808, send SMS with AT commands, consult the coordinates of GNSS, everything works fine.
But how would I make an internet connection?
Eng. Luiz Nebenzahl
nebenzahl
Post by nebenzahl » Thu Jul 04, 2019 6:18 pm
Victory!
I was able to solve it after some more research.
I want to leave the solution here for someone who needs ...
When working with SIM808 or another module that communicates with AT commands, everything is then by AT commands, even easier.
ESP32 will not have access to the internet, but it will be able to execute AT commands and in fact the SIM that will have the access.
Here below are the commands to execute URL through a SIM808.
phone.write (b '% s \ r'% ('AT + CREG?'))
print (res)
phone.write (b '% s \ r'% ('AT + SAPBR = 2,1'))
print (res)
phone.write (b '% s \ r'% ('AT + SAPBR = 1,1'))
print (res)
time.sleep (5)
phone.write (b '% s \ r'% ('AT + HTTPINIT'))
print (res)
phone.write (b '% s \ r'% ('AT + HTTPPARA = "URL", "http://gps1.aaaaa.com.br/gps_recebedados.php"'))
print (res)
phone.write (b '% s \ r'% ('AT + HTTPPARA = "CID", 1'))
print (res)
phone.write (b '% s \ r'% ('AT + HTTPACTION = 0'))
print (res)
phone.write (b '% s \ r'% ('AT + HTTPREAD'))
print (res)
phone.write (b '% s \ r'% ('AT + HTTPTERM'))
print (res)
Eng. Luiz Nebenzahl
