Makefile question
ExXec
Makefile question
Post by ExXec » Sun Jul 07, 2019 4:38 pm
Hey,
I have a problem with the "DEBUG" variable in my makefile.
It is set to 1 in the first line of my makefile and when i print it in my target it shows as "1", but the conditional for the compiler flags sees "0".
If I call make DEBUG=1 it works as expected again.
Does anyone know why this happens?
Thanks a lot!
-ExXec
DEBUG ?= 1
LINK_TIME_OPT = 1
ifeq ($(DEBUG), 1)
CFLAGS += -ggdb -DDEBUG -g -DPENDSV_DEBUG
COPT += -O0
else
COPT += -Os -DNDEBUG
# Flags for Link Time Optimization
ifeq ($(LINK_TIME_OPT), 1)
CFLAGS += -flto -fuse-linker-plugin
endif
endif
Example:
Input:
	make DEBUG=1
Output:
+ DEBUG = 1
+ Size = 257224 + 624 kiB
+ OPT-Flags: -O0
ok bc no optimization happening as intended
Input:
	make
Output:
+ DEBUG = 1
+ Size = 157568 + 624 kiB
+ OPT-Flags: -Os -DNDEBUG
Bad, optimization even though its turned off
Link to the file: https://github.com/ExXeptional/micropyt ... 3/Makefile
Code for output:
@echo +---------------------------------------------------
@echo + DEBUG = $(DEBUG)
@echo + Size = $(word 7, $(shell $(CROSS_COMPILE)size -Bd $(PROJECT_NAME).axf)) + $(word 8, $(shell $(CROSS_COMPILE)size -Bd $(PROJECT_NAME).axf)) kiB
@echo + OPT-Flags: $(COPT)
(also if anyone knows how to prperly display the size of the final binary, please do tell)
Re: Makefile question
Post by jimmo » Sun Jul 07, 2019 11:25 pm
It's the same issue as viewtopic.php?f=18&t=6573&p=37412
(You're setting DEBUG to "1 ". Remove the comment at the end of the line)
See how the stm32 prints out the elf size (I'm pretty sure using "size")
ExXec
Post by ExXec » Mon Jul 08, 2019 10:19 am
Yes that fixed it, thanks a lot! :D
