main.py does not appear to working after boot
Re: main.py does not appear to working after boot
Post by dhylands » Wed Jul 17, 2019 1:04 am
I normally put prints in boot.py and main.py if I'm trying to verify what's getting executed.
rpr
Post by rpr » Wed Jul 17, 2019 1:43 am
This maybe a silly suggestion. Put 'import main' as the last line of your boot.py. Or rename it as a different file.
Can you post your (redacted/reduced) boot.py and main.py scripts?
Edit: Other suggestions
Remove your 'boot.py' and just leave 'main.py' that blinks an LED.
Post by dhylands » Wed Jul 17, 2019 2:49 am
Just as a sanity test, I compiled the latest MicroPython for ESP32 and flashed my SparkFun ESP32 Thng. I edited the default boot.py to be:
# This file is executed on every boot (including wake-boot from deepsleep)
#import esp
#esp.osdebug(None)
#import webrepl
#webrepl.start()
print('Executing boot.py')
and I created a main.py with the single statment:
print('Executing main.py')
If I then drop into the REPL and press Control-D then I see:
MPY: soft reboot
Executing boot.py
Executing main.py
MicroPython v1.11-153-gbaea43bba on 2019-07-16; ESP32 module with ESP32
SImilarly, while in the REPL, if I press the RESET button on the ESP32 board then I see:
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4936
load:0x40078000,len:9404
load:0x40080400,len:6228
entry 0x400806ec
I (444) cpu_start: Pro cpu up.
I (444) cpu_start: Application information:
I (444) cpu_start: Compile time:     Jul 16 2019 19:39:20
I (448) cpu_start: ELF file SHA256:  0000000000000000...
I (454) cpu_start: ESP-IDF:          v3.3-beta1-694-g6b3da6b18
I (460) cpu_start: Starting app cpu, entry point is 0x40082b54
I (0) cpu_start: App cpu up.
I (471) heap_init: Initializing. RAM available for dynamic allocation:
I (478) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (484) heap_init: At 3FFB9CA8 len 00026358 (152 KiB): DRAM
I (490) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (496) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (503) heap_init: At 400921FC len 0000DE04 (55 KiB): IRAM
I (509) cpu_start: Pro cpu start user code
I (80) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
Executing boot.py
Executing main.py
In either case it seems to be executing both boot.py and main.py.
Online
Post by Roberthh » Wed Jul 17, 2019 6:22 am
@dhylands. The poster told above that when connected to a terminal, and booted via reset button or Ctrl_D, main.py is executed. It fails on pure power on. That's indeed strange: executing boot.py, but not main.py. As if that powering sets the device into RAW_REPL mode.
I tested two devices, Wemos LOLIN32 pro and sparkfun esp32 thing, here with a simple smart phone charger, and it runs main.py. Little script here. Pin 5 is connected to a LED
from time import sleep
p = Pin(5, Pin.OUT)
for _ in range(10):
    p(0)
    sleep(1)
    p(1)
    sleep(1)
Online
Post by Roberthh » Wed Jul 17, 2019 6:25 am
@smith.randallscott did we ask which ESP32 device you are using, and which firmware version?
smith.randallscott
Post by smith.randallscott » Wed Jul 17, 2019 12:49 pm
These are images of the ESP32 I am attempting to use.
smith.randallscott
Post by smith.randallscott » Wed Jul 17, 2019 12:51 pm
@dhylands Thanks for all your suggestions. I will begin trying to implement.
Online
Post by Roberthh » Wed Jul 17, 2019 1:22 pm
This module type should be fine. Which version of the firmware did you install, and did you try to
- erase the flash and
- reload the firmware?
Also, what happens if you just power the device (w/o terminal) and push the reset button (eventually labeled as EN).
smith.randallscott
Post by smith.randallscott » Wed Jul 17, 2019 1:44 pm
This is my boot.py and main.py code
boot.py
#import esp
#esp.osdebug(None)
#import webrepl
#webrepl.start()
from umqtt.robust import MQTTClient
import ds18x20
main_running_led = Pin(25, Pin.OUT)
main_running_led.on()
watch_dog_counter = 0
watch_dog_count_up = True
sta_if = network.WLAN(network.STA_IF)           #sta_if is setup outside the function so that global access is possible
client = MQTTClient('poolMQTT_client', 'xxx.xxx.xxx.xxx')
def wifi_connect():
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect('ssid', 'pass')
        while not sta_if.isconnected():
            pass
    print('network config:', sta_if.ifconfig())
sleep(3)
main_running_led.off()
#client.connect()
sleep(1)
boot_end_var = True
main.py
ow = onewire.OneWire(Pin(15))
if len(roms)>0:
    print("roms > 0")
    rom1 = roms[0]
    print("roms = {}".format(roms))
test_var = True                                     # see if main is running
def read_temp():
    sleep(0.8)
    temp_c = ds.read_temp(rom1)
    temp_f = 1.8*temp_c +32
    if temp_f > -200 and temp_f < 300:
        client.publish('garage/temperature', str(temp_f))
        print('publishing temperature {} F'.format(temp_f))
    return temp_f
wifi_connect()
client.connect()
    read_temp()
    if ((watch_dog_count_up is True) and watch_dog_counter < 20):
        watch_dog_counter = watch_dog_counter + 1
    elif watch_dog_counter >= 20:
        watch_dog_count_up = False
        watch_dog_counter = watch_dog_counter - 1
    elif ((watch_dog_count_up is False) and watch_dog_counter > 0):
    elif (watch_dog_counter <= 0):
        print('Problem with counter')
    print('counter = {}'.format(watch_dog_counter))
    if watch_dog_counter%2 == 0:
    client.publish('garage/watchdog', str(watch_dog_counter))
    sleep(5)
smith.randallscott
Post by smith.randallscott » Wed Jul 17, 2019 1:46 pm
Firmware is v1.11, I have recently (with the last 5 days) erased and re flashed with esptool
