esp32 internal temperature sensor
nebenzahl
Post by nebenzahl » Mon Jul 22, 2019 2:53 pm
I can not read the internal sensor temperature of esp32.
For I do not know which unit of measure is the integer value that I am receiving.
The [esp32.raw_temperature ()] command returns a value that I convert to Kelvin, Celsius or Fahrenheit, but no value of the result makes sense.
How do I convert the value I get?
Eng. Luiz Nebenzahl
rpr
Re: esp32 internal temperature sensor
Post by rpr » Tue Jul 23, 2019 12:58 am
The value is in deg Fahrenheit.
import esp32
tf = esp32.raw_temperature()
tc = (tf-32.0)/1.8
print("T = {0:4d} deg F or {1:5.1f}  deg C".format(tf,tc))
That said, I saw this thread on github: https://github.com/espressif/arduino-esp32/issues/2422, which mentions that this function is deprecated on newer versions of the chip.
nebenzahl
Post by nebenzahl » Tue Jul 23, 2019 1:00 pm
Thanks for the answer.
I got the same result I was getting.
I was confused, because the result was 140 ° F or 60 ° C, so I wondered, what will this temperature be like? it is very hot, and the ambient temperature I am at is 19 ° C or 66.2 ° F.
I want to control the temperature of the device, so be warned if it's too hot to melt the device.
Thanks again for the reply.
Eng. Luiz Nebenzahl
rpr
Post by rpr » Tue Jul 23, 2019 3:16 pm
I am getting about 52 deg C. This is on a cold start with no processing except a repl. Not sure what the limits are. I think devices can do 60 deg C OK.
Post by Roberthh » Tue Jul 23, 2019 8:26 pm
According to the data sheet, 125*C is the limit for the operating temperature. So 52°C is pretty comfy,
nebenzahl
Post by nebenzahl » Wed Jul 24, 2019 3:01 pm
Yes, I saw it in the datasheet. But I had doubts, because at a temperature much lower than 125 ° C some plastic materials melt.
But this temperature of 125 ° C is the internal temperature, and this is what I will be monitoring.
I have this concern, because my device will operate on vehicles, and vehicles usually remain in the scorching sun for a long time, especially in the summer of my region, that the ambient temperature reaches easy 40 ° C in the shade.
Then I will use this temperature as a parameter.
Thank you so much for your attention.
Eng. Luiz Nebenzahl
Post by Roberthh » Wed Jul 24, 2019 3:18 pm
No. The plastic used for these cases do not melt easily, not even with a soldering iron. For you estimation, you can take the difference of the core temp to the environmental temp for the estimation. Cars can get up to 80°C inside, when standing in the sun. Add the difference you have seen to 80°C.
P.S.: Actually we have >40°C here now, outside in the shade, and 34°C at my desk. In a similar weather situation, we had once seen in a corner office with nice large windows >50°C. But no one was inside. We had just set up a test how far it can get.
nebenzahl
Post by nebenzahl » Wed Jul 24, 2019 8:08 pm
Thank you for sharing your experience, I am very grateful.
I will do what you indicated, I will be estimating the temperature by comparison, then in practice I will reach more accurate values.
Thanks for the help, hug!
Eng. Luiz Nebenzahl
