How to use DAC mode normal?
Batman
Post by Batman » Tue Jul 23, 2019 7:57 pm
I am trying to output a block wave of given frequency and duration on pin x6 (DAC 2).
I can use the following to get output on pin x6. However, this seems to run forever.
dac.write_timed(buffer, 20, mode=DAC.CIRCULAR)
I was hoping I could use the following code to send a predefined signal (in buffer) to the DAC at a given sample rate. However, the following does not result in any output on the pin.
dac.write_timed(buffer, 20, mode=DAC.NORMAL)
Could someone explain to me what I am doing wrong? maybe I do not properly understand the difference between DAC.NORMAL and DAC.CIRCULAR? However, I can't find any documentation about what these flags are supposed to do.
I have posted a minimal, self-contained example below if someone wants to test it. This is a minimally working example:
import math
from pyb import DAC,delay
wave =  [255,0] * 10
buffer = bytearray(wave)
# This does produce a block wave on pin x6
print('Start 1')
dac = DAC(2)
delay(5000)
# This does not give me any output on pin x6
print('Start 2')
dac = DAC(2)
delay(2000)
Re: How to use DAC mode normal?
Post by jimmo » Wed Jul 24, 2019 2:05 am
I can repro this problem on a pybv1.1.
I think your understanding of CIRCULAR and NORMAL matches mine :) (Normal does a single transmission of the waveform, circular loops it).
I'll investigate and get back to you.
Post by jimmo » Wed Jul 24, 2019 7:20 am
I had a quick look, nothing obvious jumped out at me. Raised https://github.com/micropython/micropython/issues/4944
Batman
Post by Batman » Wed Jul 24, 2019 1:57 pm
Thank you for checking and raising the issue.
In case this informative, I have just installed this firmware version:
pybv11-20190722-v1.11-167-g331c224e0.dfu
Batman
Post by Batman » Thu Jul 25, 2019 2:36 pm
Great! The issue seems be fixed as per
Will a new dfu file become available?
Post by jimmo » Thu Jul 25, 2019 11:34 pm
I think they update daily, although there don't appear to be any pyb v1.1 nightly builds on the download page right now? If it doesn't show up later today I'll do a build for you and upload it somewhere.
Batman
Post by Batman » Thu Aug 01, 2019 4:54 pm
I flashed the new firmware and I can confirm this issue is solved. Great work.
