adding a timeout to wifi connexion
LukeVideo
Post by LukeVideo » Tue Jul 30, 2019 1:05 pm
Hy, I'm using the sample from the documentation to connect my esp32 boards.
def connect():
    from utils.conf import ip, subnet, gateway, dns, ssid, password
    station = network.WLAN(network.STA_IF)
    if station.isconnected() == True:
        print("Already connected")
        return
    station.active(True)
    station.ifconfig((ip,subnet,gateway,dns))
    station.connect(ssid, password)
    while station.isconnected() == False:
        pass
    print("Connection successful")
    print(station.ifconfig())
def disconnect():
    station.disconnect()
    station.active(False)
i am trying to add a way to handle the absence of my AP ( a raspberry Pi that might be out of range or turned off) but this just loops forever:
    connect()
except:
    print("no connectWifi")
    disconnect()
and it spams the console with :
no AP found
I (64636) wifi: STA_DISCONNECTED, reason:201
no AP found
I (66696) wifi: STA_DISCONNECTED, reason:201
Any idea how to handle this ? I need my program to run even if the connection is down.
Re: adding a timeout to wifi connexion
Post by jimmo » Tue Jul 30, 2019 2:39 pm
I haven't used ESP32, but my memory from ESP8266 is that connect() returns immediately then connects in the background (so you can poll with isconnected or status).
So if ESP32 is the same, then your code will be stuck in the `while station.isconnected()` loop. In which case use utime.ticks_ms() before the loop, then utime.ticks_diff() inside the loop to figure out how much time has passed and break out of the loop after enough time has elapsed.
LukeVideo
Post by LukeVideo » Tue Jul 30, 2019 2:43 pm
That look like the way it's behaving.
I'll try that, thank you.
LukeVideo
Post by LukeVideo » Tue Aug 06, 2019 7:46 am
i added this to the connection routine
        presentTime = time.ticks_ms()
        duration = presentTime - startTime
        if duration > 5000:
            break
        pass
Works like a charm.
