Driver for SHT31 Sensor Module
Hasenradball
Post by Hasenradball » Fri Aug 02, 2019 7:17 am
Hi Guys,
do anyone have an hint for me which driver is ready to use in micropython with the ESP8266 to measure temperature and humidity for the Sensirion SHT31 module?
Re: Driver for SHT31 Sensor Module
Post by jimmo » Fri Aug 02, 2019 12:52 pm
Did you have any luck with https://github.com/kfricke/micropython-sht31
It just uses machine.I2C, so it should work on the ESP8266.
Hasenradball
Post by Hasenradball » Sat Aug 03, 2019 7:06 am
Hi thank you,
I am searching for an driver with implemented CRC Check and allerts.
And the description says this is actually not done.
Is there an alternative driver available?
