QSTR is mentioned a lot in this forum, but other than a short blurb about it under the "Storing strings in flash" section here there doesn't seem to be any concrete examples. I imported my main module and ran the command micropython.qstr_info(1) and the only thing it returned was the name of the module I imported. I guess I was expecting to see... more.
A few questions:
1.) My main module imports a lot of other modules, does micropython.qstr_info(1) run recursively, or do I need to import every single module that ever gets imported before I run micropython.qstr_info(1)?
2.) Will micropython.qstr_info(1) only ever return module names, or will it return actual strings that are in my code?
3.) Does adding QSTRs to qstrdefsport.h work if my modules are already frozen?
A concrete QSTR example
Re: A concrete QSTR example
If your modules are already frozen, then your strings have already been QSRT-ified.
