disable_irq() error on ESP32
water
Post by water » Sat Aug 03, 2019 3:05 pm
I disable IRQ on ESP32 via
disable_irq()
, error occur appear the message below, and reboot:
>>> disable_irq()
395552
>>> Guru Meditation Error: Core  0 panic'ed (Interrupt wdt timeout on CPU0)
Core 0 register dump:
PC      : 0x400910d3  PS      : 0x00060b34  A0      : 0x800f3814  A1      : 0x3ffc1960
A2      : 0x3ffb2fe0  A3      : 0x00000000  A4      : 0x3ffb302c  A5      : 0x00000000
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x800910d3  A9      : 0x3ffc1940
A10     : 0x3ffb2fe0  A11     : 0x00000000  A12     : 0x000005a1  A13     : 0x3f420221
A14     : 0x0000cdcd  A15     : 0x3ffc18dc  SAR     : 0x0000001e  EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xfffffffe
Backtrace: 0x400910d3:0x3ffc1960 0x400f3811:0x3ffc19a0 0x400f01ce:0x3ffc19c0 0x400f7169:0x3ffc19e0 0x400f77d7:0x3ffc1a00 0x400f00dc:0x3ffc1a40 0x4009086d:0x3ffc1a70
Core 1 register dump:
PC      : 0x4018a5d6  PS      : 0x00060134  A0      : 0x80102686  A1      : 0x3ffbc980
A2      : 0x3ffb3985  A3      : 0x00060120  A4      : 0x00060620  A5      : 0x00000001
A6      : 0x0000abab  A7      : 0x00060023  A8      : 0x80102ab5  A9      : 0x3ffbc970
A10     : 0x00000003  A11     : 0x00060123  A12     : 0x00060120  A13     : 0x00000000
A14     : 0x00060020  A15     : 0x00000000  SAR     : 0x0000001d  EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Backtrace: 0x4018a5d6:0x3ffbc980 0x40102683:0x3ffbc9a0 0x40091f25:0x3ffbc9c0 0x4009086d:0x3ffbc9f0
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
is it normally ? or ESP32 not support disable_irq() function ?
Re: disable_irq() error on ESP32
Post by Roberthh » Sat Aug 03, 2019 4:35 pm
Interrupt must be disabled only for a very short time. Otherwise the WDT will reboot the device. That's what you have seen.
A typical use case is:
Disable IRQ
Perform a short action
Enable IRQ
water
Post by water » Sat Aug 03, 2019 10:43 pm
Thanks.
How can I list which IRQs allocated and theirs parameter currently ? (if I forgot them) ;)
and can I delete specific one ?
is it have multi priority level concept in Micropython ? the document looks like not more notice.
