Flash Esp32 from another Esp32
Marius
Post by Marius » Tue Aug 20, 2019 6:51 am
Is it possible to use a Micropython based Esp32 to flash another one? I guess the esptool is not a straight forward port to mp.
Re: Flash Esp32 from another Esp32
Post by jimmo » Tue Aug 20, 2019 7:10 am
Just to confirm - you'd like to use one ESP32 to program the actual firmware on another ESP32 (not just update/modify just the Python code / filesystem contents).
I'd imagine it was probably do-able (to port esptool.py to micropython). Especially if you strip out everything that isn't firmware upload. It has a few library dependencies that aren't in MicroPython, but many of them look like they might not be used for the upload firmware code path.
danielm
Post by danielm » Tue Aug 20, 2019 11:15 am
I am also interested in this.
The goal: To build tester device based on MP which would be able to flash specific firmware into target device.
