umqtt_simple - bytes index out of range new error
devnull
Post by devnull » Tue Sep 03, 2019 12:00 pm
Just updated micropython on the SF2 and are now noticing mqtt errors (umqtt_simple line 84) during the connection process.
This tries to connect 3 times and if it fails will goto sleep and try again later.
But I don't recall seeing this "bytes index out of range" error ever before, and I have been using this umqtt_simple module for several years.
Could this be something that has been introduced due to updates in micropython v1.11-218-g3eff81288 or am I barking up the wrong tree and this is just a coincidence ??
Client: 484a300173f0 mqtt.thingspeak.com 1883
mqtt-connecting...
mqtt-connect error
mqtt-connecting...
mqtt-connect error
mqtt-connecting...
Pete
Re: umqtt_simple - bytes index out of range new error
Post by jimmo » Tue Sep 03, 2019 1:02 pm
Are you able to add some debugging to umqtt/simple.py
It seems pretty surprising that -- `premsg = sz` could be failing because i would have to be >= 6, which means that sz was a very large number? But this code looks like it mostly only uses data provided by the user, so hopefuly some print() statements will explain pretty quickly.
devnull
Post by devnull » Tue Sep 03, 2019 1:13 pm
Hello Jimmo, thanks for helping.
Sorrie, specifying the line number was misleading as I maye have added some comments to the top of the file, this in fact is line 84:
assert resp[0] == 0x20 and resp[1] == 0x02
Cheers
PeterC
devnull
Post by devnull » Tue Sep 03, 2019 11:34 pm
When I revert back to an older build, the problem goes away and connection is successful every time with no errors:
MicroPython v1.9.3-1869-ga9b1d3ca3
Using my latest, I get the bytes index out of range errors, and it very very rarely connects:
Post by jimmo » Tue Sep 03, 2019 11:46 pm
Ok interesting! Do you have some simple steps I can use to repro on my SF2 board?
devnull
Post by devnull » Wed Sep 04, 2019 7:19 am
Hi;
Thanks so much for offering help Jimmo, I have yet to debug myself, this is already mounted to a PCB and boxed.
I need to first do some basic debugging and potentially create some steps to replicate.
Will get beck to you once I have done that.
devnull
Post by devnull » Wed Sep 04, 2019 10:23 am
OK, here's some debug info that has been added to mqtt_simple:
This is the code from mqtt_simple:
        self.sock.write(premsg, i + 2)
        self.sock.write(msg)
        print('dbug-msg:',hex(len(msg)), hexlify(msg, ":"))
        self._send_str(self.client_id)
        if self.lw_topic:
            self._send_str(self.lw_topic)
            self._send_str(self.lw_msg)
        if self.user is not None:
            self._send_str(self.user)
            self._send_str(self.pswd)
        resp = self.sock.read(4)
        print('dbug-resp:',resp)
        if resp[3] != 0:
            raise MQTTException(resp[3])
        return resp[2] & 1
This is the output using MicroPython v1.11-218-g3eff81288 which fails after 3 attempts;
mqtt-connecting...
dbug-msg: 0x9 b'04:4d:51:54:54:04:02:00:00'
dbug-resp: b''
dbug-resp: b''
dbug-resp: b''
And this is using MicroPython 1.9.3-1869-ga9b1d3ca3 which succeeds on first attempt:
mqtt-connecting...
dbug-resp: b' \x02\x00\x00'
devnull
Post by devnull » Wed Sep 04, 2019 11:40 pm
Can anybody else confirm with a live mqtt setup (simple_mqtt or robust_mqtt) on the pyboard D series that mqtt is working for them ??
My gut feeling is that this is somehow related to the socket, as this code is pretty much only reading and writing to the socket and is not getting a reply.
