I saw some pictures of the lcd160cr -->v1.1<- with wbus connectors.
Is this board fully compatible with the d-series boards? And if so why is this display not showed in the shop by the d-series boards?
grtz. Ron Cromberge
Does the "lcd160cr" fully compatible with the d-series pyboard?
- roncromberge
I'm a novice u-Python/Controller user. So don't shoot me when i talk nonsense.
All text is translated from NL2EN via google. So excuse me for some strange English translations.
Re: Does the "lcd160cr" fully compatible with the d-series pyboard?
Yes, the addition of the wbus connector is the main difference between 1.0 and 1.1. It works well with the pybd, I have one.
I'll let the store admin know. I agree, they probably should be in the pybd section.
It does indeed work well. I pointed out to Damien a while back that the way the store is laid out doesn't make it obvious.
The other issue I mentioned is that it would be good if there were documentation showing what pins brought out on the LCD160CR are available for use when plugged into a Pyboard D. Figuring it out from the schematics looks laborious.
- roncromberge
Thanks for the info.
Next thing to get... when my bank saldo is restored
