html to variable
bellad
html to variable
Post by bellad » Thu Sep 12, 2019 7:39 am
hello,
i would collect 2variable in html to micropython , but how to do ?
<p align="center" style="margin-bottom: 0cm; line-height: 100%"><B>Demande exceptionnelle</B></p>
  <div>
    <input type="text" id="name1" name="name1" required
       minlength="2" maxlength="2" size="3">
	   <label for="Choi1"> Degrés  |  </label>
	<input type="text" id="name2" name="name2" required
       minlength="1" maxlength="2" size="2">
       <label for="Choi2">Heure(s) |</label>
      <p align="center" style="margin-bottom: 0cm; line-height: 100%"><input type="submit" value="Enregistrer">
   </div>
thank you
sorry for my english , i use google translate
ThomasChr
Re: html to variable
Post by ThomasChr » Fri Sep 13, 2019 9:30 am
One way would be to have the html elements in a <form> element with a submit-Tag which has the address of the pyboard in it. Whenever you submit the form the values of the variables will be submitted with it, either in the url (method=get) or in the body (method=post) of the request.
A little bit more complicated would be a Javascript xmlhttprequest. This can be totally asynchronous and the data format can be more changed by you, for example JSON.
Thomas
bellad
Post by bellad » Fri Sep 13, 2019 12:16 pm
thank you Thomas
do you have an example?
Post by jimmo » Fri Sep 13, 2019 12:19 pm
Take a look at "microdot" which is a web server for MicroPython. It includes an example that has a web page that lets you control a GPIO pin.
https://github.com/miguelgrinberg/microdot
bellad
Post by bellad » Fri Sep 13, 2019 12:36 pm
thank's , ok I study the example
bellad
Post by bellad » Mon Nov 18, 2019 3:47 pm
hello,
sorry but is a mystery to me.
<form action=”” method=”POST”>
       minlength="2" maxlength="2" size="3" >
	   <label for="contactChoice1"> Degres_    </label>
       minlength="1" maxlength="2" size="2" >
       <label for="contactChoice1">Heure(s) </label>
      <p align="center" style="margin-bottom: 0cm; line-height: 100%"><button type="submit">Enregistrer</button><p/>
   </form>
 if request.method == 'POST':
    deg=request.form['name1']
    laps=request.form['name2']
AttributeError: 'str' object has no attribute 'method'
but i two request one for
conn, addr = s.accept()
  #print('Got a connection from %s' % str(addr))
  request = conn.recv(1024)
  request = str(request)
  #print('Content = %s' % request)
  led_on = request.find('/?led=on')
  led_off = request.find('/?led=off')
  led2_on = request.find('/?led2=on')
  if led_on == 6:
    mode="Travail"
   # print('LED ON')
and one for
    import urequests as requests
except ImportError:
    import requests
import socket
I would like to recover the values name1 and name2 in variables deg and laps ,
can you help
thank you
Post by jimmo » Mon Nov 18, 2019 9:03 pm
urequests is for sending HTTP requests, so that won't help here.
Did you take a look at microdot? It takes care of this for you. Let us know if we can help you get that set up.
bellad
Post by bellad » Tue Nov 19, 2019 8:52 am
i see microdot , but i think that it's going to overload the ram on my esp12 , because my prog is already substantial
for 2 variable there is no other less cumbersome solution ?
thank
bellad
Post by bellad » Wed Nov 20, 2019 9:44 am
I found a solution
i search in 'request 'variable and retrieve data
lalongo
Post by lalongo » Wed Apr 29, 2020 12:34 pm
Hello Bellad,
I have the same issue than you but I cannot understand what do you mean by :
"i search in 'request 'variable and retrieve data"
Can you be more specific ? It would be really helpfull :D
