Could not format the SD card by command : os.VfsFat.mkfs(sd)
woot_srx
Post by woot_srx » Wed Oct 09, 2019 3:55 am
I could mount the SD card then write and read files, but sometime I found files corrupted.
So I want to format the SD card by os.VfsFat.mkfs(sd) but I got error.
My code for mounting SD card:
=== from machine import Pin,SPI
=== import json, sdcard, os,time
=== def SD_BEGIN():
===     spi = SPI(sck=Pin(13), mosi=Pin(23), miso=Pin(22))
===     spi.init()  # Ensure right baudrate
===     sd = sdcard.SDCard(spi, Pin(21)) # Compatible with PCB
===     vfs = os.VfsFat(sd)
===     os.mount(vfs, '/sd')
===     print('Filesystem check')
===     print(os.listdir())
===     print(os.listdir('/sd'))
=== SD_BEGIN()
Filesystem check
['sd', 'boot.py', 'sdcard.py', 'LOG']
['System Volume Information', '010001.txt']
When I format the SD card, I got error
=== os.VfsFat.mkfs(sd)
  File "<stdin>", line 6, in <module>
OSError: [Errno 5] EIO
Could you please suggest me? How shall i do?
Thank you in advance.
Re: Could not format the SD card by command : os.VfsFat.mkfs(sd)
Post by Roberthh » Wed Oct 09, 2019 6:07 am
For an example about how-to, you may look in https://github.com/micropython/micropyt ... 32/modules at the files inisetup.py and flashbdev.py.
woot_srx
Post by woot_srx » Fri Oct 11, 2019 4:21 am
Thank you so much, i will study according your suggestion.
