uasyncio example study
koufdell
Post by koufdell » Fri Oct 11, 2019 9:23 pm
peace everyone
new in the world of micropython , i came across uasyncio and searched for a basic example
after some tries i have some questions:
what's the meaning of runleq as argument of uasyncio.get_event_loop() ?
is this example valid?
using uasyncio 2.0 on a esp 01
import utime
import uasyncio
def is_prime(x):
return not any(x//i == x/i for i in range(x-1,2,-1))
async def highest_prime_below(x):
print('Highest prime below %d' %x)
for y in range(x-1,0,-1):
if is_prime(y):
print('highest prime below %d is %d' % (x,y))
return y
#await uasyncio.sleep_ms(1)
yield
return None
async def finish():
t0 = utime.ticks_ms()
while len(loop.runq)!=0:
t1 = utime.ticks_ms()
print('done in {:2f} secs'.format((t1-t0)/1000))
loop.stop()
loop.close()
loop = uasyncio.get_event_loop()
loop.create_task(highest_prime_below(20000))
loop.create_task(highest_prime_below(30000))
loop.create_task(highest_prime_below(100))
loop.create_task(highest_prime_below(37562))
loop.create_task(finish())
loop.run_forever()
thx everyone..
Re: uasyncio example study
Post by pythoncoder » Sat Oct 12, 2019 6:31 am
I advise against polling runq. You can initialise the event loop to use larger run and time queues. This is only necessary in applications with a large number of concurrent tasks. In most applications you initialise the event loop with
and then ignore the run and time queues: these are internal to uasyncio and are not part of its API.
You will find a tutorial on uasyncio and numerous example scripts in this repository.
Post by pythoncoder » Sat Oct 12, 2019 7:09 am
To add to my comments, your is_prime() function does an equality test between a float with an integer. This is not good practice because of imprecision in the way floats are represented as machine words. You should use the modulus operator:
def is_prime(x):
    return all(x % i for i in range(x-1, 1, -1))
Also, to ensure that division by 2 is tested, the range should be as above. Otherwise 4 will be reported as prime.
I'm sure you're aware that though this is simple it is not an efficient way of testing primality.
koufdell
Post by koufdell » Sat Oct 12, 2019 1:07 pm
thank you for your time sir
is it better to define a loop.run_until_complete() handler or use the logic i came up with(watching the queue and stopping the loop.run_forever())
if so what handler should i write for loop.run_until_complete()
Post by pythoncoder » Sun Oct 13, 2019 6:48 am
As stated above I don't think you should watch the queue*. There are better ways of testing whether coroutines have run to completion which don't require knowledge of uasyncio internals. The simplest is to have each set a global boolean before they terminate, with the main coroutine looping (with a delay) until all flags were set. More Pythonic would be to create a class: have the coroutines as bound methods and have the flags as bound variables.
My preferred solution would be to use the synchronisation primitives which may be found in this repo. A Barrier instance can cause a coroutine to pause until all members of a set of other coroutines have run to completion.
*Watching the run queue would not actually work if your coroutines have nonzero delays because of the relationship between runq and timeq.
koufdell
Post by koufdell » Sun Oct 13, 2019 10:57 am
thx sir for your time again much appreciated
