Unregistering an EXTI - pyb
lnsri22
Post by lnsri22 » Sat Nov 02, 2019 9:59 am
Hello Everyone!!
I am trying to use EXTI with pyb. How do I un register a previously registered interrupt and register it again.
Thanks!!
lnsri22 :)
Re: Unregistering an EXTI - pyb
Post by jimmo » Mon Nov 04, 2019 12:48 am
Are you using pyb.ExtInt ? http://docs.micropython.org/en/latest/l ... xtInt.html
You can use the enable and disable methods.
Otherwise if you're using Pin interrupts (i.e. machine.Pin), you can use pin.irq(handler=None) to disable the interrupt.
lnsri22
Post by lnsri22 » Thu Nov 07, 2019 6:02 am
Thanks for the suggestion!!
Let me give it a try and get back
lnsri22 :)
