timeit function not available in machine module
giri
Post by giri » Thu Nov 07, 2019 2:43 pm
I went through some posts here but could not find them helpful
I used esptool for importing micropython into my wemos D1 mini
However, I'm trying to find a way to calculate code execution time using in-built function 'timeit',
but it's not there
Anybody found a solution for this
Re: timeit function not available in machine module
Post by jimmo » Thu Nov 07, 2019 8:47 pm
To save space, MicroPython doesn't include the whole of the Python standard library.
However you can install some things (including timeit) manually from micropython-lib -- e.g. https://github.com/micropython/micropyt ... ter/timeit
Post by Roberthh » Thu Nov 07, 2019 9:02 pm
That timeit function in the micropython-lib looks like overkill, and certainly not made for esp8266.
In that situation, I usually time a function using utime.ticks_us() and utime.ticks_diff().
Edit: I faintly remember that Dave @dhylands had written something more reusable, but than might have been for the old PyBoard API.
giri
Post by giri » Sat Nov 09, 2019 9:03 am
Ok I will test it
giri
Post by giri » Sat Nov 09, 2019 9:05 am
I will check
Post by pythoncoder » Sat Nov 09, 2019 9:16 am
You'll find a way to time a function call using a decorator here e.g.
@timed_function
def test():
    utime.sleep_us(10000)
giri
Post by giri » Thu Nov 14, 2019 3:16 pm
@timed_function
def test():
Ok
I'll test
In case of any doubt I'll get back to you
