UART function
jk007
UART function
Post by jk007 » Tue Nov 12, 2019 2:11 am
Hello, I'm afraid that I'm from China. I'm using pyb1.1. When using the official firmware version v1.93, UART (2) can use UART.readline() to read a row of data normally, but this version can't use ssd1306. When using the official firmware version v1.11, ssd1306 can be driven, but the data obtained by UART. readline() is a single letter. Where can I see the differences between versions? Thank you
from pyb import DAC, Pin, ADC, UART
uart = UART(2, 9600)
    if uart.any():
        data = uart.readline()
        print(data)
##################debug from v1.11##################
MicroPython v1.11 on 2019-05-29; PYBv1.1 with STM32F405RG
MPY: sync filesystems
MPY: soft reboot
b'H'
b'e'
b'l'
b'l'
b'o'
##################debug from v1.9.3 ##################
MicroPython v1.9.3 on 2017-11-01; PYBv1.1 with STM32F405RG
PYB: sync filesystems
PYB: soft reboot
b'Hello'
As you can see, with the same code, the output information of different firmware versions is different. V1.93 gets' hello ', while v1.11 gets' H', 'e', 'l', 'l', 'o'
Re: UART function
Post by jimmo » Tue Nov 12, 2019 2:35 am
I think the change was that earlier this year (commit 34942d0a72980173eca51b201f271f67bcae46b5) the default timeout for the UART on STM32 was changed from 1000ms to 0ms (i.e. non-blocking).
So to get the old behavior back, use
uart = UART(2, 9600, timeout=1000)
jk007
Re: UART function
Post by jk007 » Thu Nov 14, 2019 6:10 am
OK, thank you. I'll try
