Bypass password and key input in webrepl
ajie_dirgantara
Post by ajie_dirgantara » Sat Nov 23, 2019 10:05 am
I would like to bypass webrepl password input.
By disabling password checking in webrepl.py
def start(port=8266, password=None):
    stop()
    if password is None:
            import webrepl_cfg
            #_webrepl.password(webrepl_cfg.PASS)
            setup_conn(port, accept_conn)
            print("Started webrepl in normal mode")
        except:
            print("WebREPL is not configured, run 'import webrepl_setup'")
        #_webrepl.password(password)
        print("Started webrepl in manual override mode")
It works just fine, but it still needs to press enter.
What I am after is connected automatically after clicking the "connect" button in the browser.
What I've been looking for is likely to modify the extmod/modwebrepl.c, and recompile the firmware. But I am pretty noobs in C programming, so it would be great if someone pointed which line to modify. From what I've seen it should be enough by modifying somewhere along this line :
https://github.com/micropython/micropyt ... epl.c#L106
STATIC mp_obj_t webrepl_make_new(const mp_obj_type_t *type, size_t n_args, size_t n_kw, const mp_obj_t *args) {
    mp_arg_check_num(n_args, n_kw, 1, 2, false);
    mp_get_stream_raise(args[0], MP_STREAM_OP_READ | MP_STREAM_OP_WRITE | MP_STREAM_OP_IOCTL);
    DEBUG_printf("sizeof(struct webrepl_file) = %lu\n", sizeof(struct webrepl_file));
    mp_obj_webrepl_t *o = m_new_obj(mp_obj_webrepl_t);
    o->base.type = type;
    o->sock = args[0];
    o->hdr_to_recv = sizeof(struct webrepl_file);
    o->data_to_recv = 0;
    o->state = STATE_PASSWD;
    write_webrepl_str(args[0], SSTR(passwd_prompt));
    return o;
Re: Bypass password and key input in webrepl
Post by jimmo » Sat Nov 23, 2019 11:37 am
I haven't tested this, but took a quick look at the code.
As you can see in the bit that your highlighted, the relevant two lines are at the end. Webrepl has a current state (which is how it decides how to handle any incoming input). So it starts in STATE_PASSWD, and then transmits hte password prompt.
If you look at _webrepl_read, it then checks the incoming password and moves to STATE_NORMAL.
So my guess would be if you modify webrepl_make_new to instead set o->state = STATE_PASSWD and change the line that sends the password prompt to instead send the connected prompt, then hopefully you'll have what you need.
i.e.
    o->state = STATE_NORMAL
    write_webrepl_str(args[0], SSTR(connected_prompt));
    return o;
ajie_dirgantara
[SOLVED] Re: Bypass password and key input in webrepl
Post by ajie_dirgantara » Mon Nov 25, 2019 1:56 pm
Yes, I've been successfully bypass password by change STATE_PASSWD to STATE_NORMAL like below.
    o->sock = args[0];
    o->state = STATE_NORMAL;
    //write_webrepl_str(args[0], SSTR(passwd_prompt));
    return o;
