.bin failed-genhdr-mpversion-ERROR
vikram20
Post by vikram20 » Sat Dec 28, 2019 9:23 am
Hi
Can anyone help me for CC3200LAUNCHXL Micropython porting?
I followed Ti/WiKi page guidelines for porting.
1. Successfully generated bootloader file.
2. Started mcumg.bin generation but failed in between and stuck up at the pins.h build then build it with python code.
3. Again error generated for mpversion.h build then build it with python but after making application it shows the same mpversion.h error and could not proceed after it. Struggling on it for last 3days tried many thing like uninstall/install micropython/Cygwin also.
Iam using - micropython-1.12/micropython-master
windows 64
cygwin
below is the screen code for same.
Lenovo@DESKTOP-0GNP05U ~
$ cd e:/micropython
 Create bootmgr/build/LAUNCHXL/release/bootloader.bin
Relocator found...
Boot Manager found...                                                           Generating bootloader...
Lenovo@DESKTOP-0GNP05U /cygdrive/e/micropython-master/ports/cc3200
$ make BTARGET=application BTYPE=release BOARD=LAUNCHXL
Create build/LAUNCHXL/release/genhdr/pins.h
bash: python3: command not found
application.mk:236: recipe for target 'build/LAUNCHXL/release/genhdr/pins.h' failed
make: *** [build/LAUNCHXL/release/genhdr/pins.h] Error 127
stijn
Re: .bin failed-genhdr-mpversion-ERROR
Post by stijn » Sat Dec 28, 2019 11:15 am
That's the first thing to solve. Invoke with 'make PYTHON=/full/path/to/python3' or set PATH environment variable so that the python3 executable is in your path.
vikram20
Post by vikram20 » Sat Dec 28, 2019 3:36 pm
Hi stjin
Thanks for your support.
Python is on the path as I started with it initially.
I attached the code and it shoes error on the 'mpversion.h' file.
$ cd E:/micropython-1.12/ports/cc3200
Lenovo@DESKTOP-0GNP05U /cygdrive/e/micropython-1.12/ports/cc3200
$ make BTARGET=bootloader BTYPE=release BOARD=LAUNCHXL
mkdir -p bootmgr/build/LAUNCHXL/release/genhdr
touch bootmgr/build/LAUNCHXL/release/genhdr/qstrdefs.generated.h
touch bootmgr/build/LAUNCHXL/release/genhdr/mpversion.h
mkdir -p bootmgr/build/LAUNCHXL/release/bootmgr/
mkdir -p bootmgr/build/LAUNCHXL/release/drivers/cc3100/src/
mkdir -p bootmgr/build/LAUNCHXL/release/hal/
mkdir -p bootmgr/build/LAUNCHXL/release/lib/libc/
mkdir -p bootmgr/build/LAUNCHXL/release/lib/utils/
mkdir -p bootmgr/build/LAUNCHXL/release/misc/
mkdir -p bootmgr/build/LAUNCHXL/release/py/
mkdir -p bootmgr/build/LAUNCHXL/release/simplelink/
mkdir -p bootmgr/build/LAUNCHXL/release/util/
CC hal/cpu.c
CC hal/interrupt.c
CC hal/gpio.c
CC hal/pin.c
CC hal/prcm.c
CC hal/shamd5.c
CC hal/spi.c
CC hal/startup_gcc.c
CC hal/systick.c
CC hal/utils.c
CC simplelink/cc_pal.c
CC ../../drivers/cc3100/src/device.c
CC ../../drivers/cc3100/src/driver.c
CC ../../drivers/cc3100/src/flowcont.c
CC ../../drivers/cc3100/src/fs.c
CC ../../drivers/cc3100/src/netapp.c
CC ../../drivers/cc3100/src/netcfg.c
CC ../../drivers/cc3100/src/nonos.c
CC ../../drivers/cc3100/src/socket.c
CC ../../drivers/cc3100/src/spawn.c
CC ../../drivers/cc3100/src/wlan.c
CC util/cryptohash.c
CC misc/antenna.c
CC misc/mperror.c
CC bootmgr/main.c
AS bootmgr/runapp.s
CC ../../py/mpprint.c
CC ../../lib/libc/string0.c
CC ../../lib/utils/printf.c
LINK bootmgr/build/LAUNCHXL/release/bootmgr.axf
   text    data     bss     dec     hex filename
  11496       0    1997   13493    34b5 bootmgr/build/LAUNCHXL/release/bootmgr.a
xf
Create bootmgr/build/LAUNCHXL/release/bootmgr.bin
Relocator found...
mkdir -p build/LAUNCHXL/release/genhdr
$ python boards/make-pins.py --board boards/LAUNCHXL/pins.csv --af boards/cc3200_af.csv --prefix boards/cc3200_prefix.c --hdr build/LAUNCHXL/release/genhdr/pins.h --qstr build/LAUNCHXL/release/pins_qstr.h>build/LAUNCHXL/release/pins.c
../../py/py.mk:232: recipe for target 'build/LAUNCHXL/release/genhdr/mpversion.h' failed
make: *** [build/LAUNCHXL/release/genhdr/mpversion.h] Error 127
$ python ../../py/makeversionhdr.py build/LAUNCHXL/release/genhdr/mpversion.h
GEN build/LAUNCHXL/release/genhdr/mpversion.h
vikram20
Post by vikram20 » Mon Dec 30, 2019 7:55 am
Hi
Does anyone has a solution for above problem?
Post by Roberthh » Mon Dec 30, 2019 8:03 am
As states several time, the reason is shown by the line:
python3 is missing. So if python3 is not in the path, you have to specify it in tghe make command with
make PYTHON=<path of a python3 executable> ...all other options....
e.g., if you can call python3 from the command line:
make BTARGET=application BTYPE=release BOARD=LAUNCHXL PYTHON=python3
stijn
Post by stijn » Mon Dec 30, 2019 8:16 am
Just to be clear: the error is about python3 so it doesn't matter whether python is in your path.
vikram20
Post by vikram20 » Mon Dec 30, 2019 1:29 pm
Thanks for solution.
