reading socket into buffer and then reading buffer by line
devnull
Post by devnull » Sun Dec 29, 2019 2:38 am
I need to read from the socket and cannot use readline() as it is possible that the data does not contain line endings, in which case it will wait forever.
So I am reading into a byte string as per the code below, however I realise that using a byte string may not be as efficient as reading into a buffer which I have no experience with.
The following code works, but is the method I am using the best way to do this ?? - I need to be able to read by length, line and to pop the data off the buffer after reading it.
inbuf = b''
def read():
  inbuf += self.sock.read()
  return len(self.inbuf)
def readbuf(size=0,pop=True,line=False):
  os = 0
  if line:
    os=2
    size = inbuf.find(b'\r\n')
    if size < 0: size = 0
  data = inbuf[:size]
  if pop: inbuf = self.inbuf[size+os:]
  return data
devnull
Re: reading socket into buffer and then reading buffer by line
Post by devnull » Sun Dec 29, 2019 6:23 am
This is an attempt at readline using a byte array:
a = bytearray(b'0123\r\n45678\r\n9\r\n\r\n')
def readline():
	global a
	data=a
	old=None
	for i in range(len(a)):
		new = a[i]
		if old == 13 and new == 10:
			data = a[:i-1]
			a=a[i+1:]
			return data
		old = new
	a = bytearray()
	return data
>>> readline()
bytearray(b'0123')
>>> readline()
bytearray(b'45678')
>>> readline()
bytearray(b'9')
>>> readline()
bytearray(b'')
Same question, is there a better way ??
devnull
Post by devnull » Sun Dec 29, 2019 7:19 am
OK, forget these requests for help, I have solved the problem by using select.poll() on the socket.readline()
