where to place the web request ?
bellad
Post by bellad » Thu Jan 16, 2020 2:15 pm
hello,
with my prog , i have placed my web request in the loop , but I need to update my page for running my loop , what awaits my prog and does not do its job
thank you for your answer
import utime
import os
from bme280 import *
g=0
rel= machine.Pin(12, machine.Pin.OUT)
led = machine.Pin(13, machine.Pin.OUT)
  import usocket as socket
except:
  import socket
  import ustruct as struct
except:
  import struct
# (date(2000, 1, 1) - date(1900, 1, 1)).days * 24*60*60
NTP_DELTA = 3155673600
mo=('Travail','Presence','absence','exception')
jr=('Lundi','Mardi','Mercredi','Jeudi','Vendredi','Samedi','Dimanche')
host = "192.168.1.79" # serveur ntp interne
hosts="0.fr.pool.ntp.org" # serveur ntp internet
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('', 80))
s.listen(5)
excep=''
h1='#0F3376'
ab=0
m=0
mm=0
def temp():
  l=open('te.txt','r')
  li=l.read()
  bmp=BME280(i2c=i2c, address=BME280_I2CADDR)
  ts=bmp.raw_values
  temper=ts[0]
  return round(temper+float(li),2)
def web_page():
  tempera=str(temp())+' / '+str(tempf)
  ddt=jr[u[6]]+' '+str(u[3])+' h '+str(u[4])
  html = """<html><head> <title>Chambre parentale</title> <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="icon" href="data:,"> <style>html{font-family: Helvetica; display:inline-block; margin: 0px auto; text-align: center;}
  h1{color: """+h1+"""; padding: 2vh;}p{font-size: 1.5rem;}.button1{display: inline-block; background-color: #ed7a0e; border: double;
  border-radius: 4px; color: white; padding: 3px 5px; text-decoration: none; font-size: 20px; margin: 2px; cursor: pointer;}
  .button2{display: inline-block; background-color: #0c2f5c; border: double; border-radius: 4px; color: white; padding: 3px 5px ;
  .button3{display: inline-block; background-color: #0c5c13; border: double; border-radius: 4px; color: white; padding: 3px 5px ;
  text-decoration: none; font-size: 20px; margin: 2px; cursor: pointer;}</style></head><body> <h1>Chambre parentale</h1>
  <p>"""+ddt+"""</p>
  <p>Temperature: <strong>""" + tempera + """</strong><p>Mode: <strong>""" + mo[ab] + """</strong></p><p><a href="/?led=on"><button class="button1">Travail</button></a>
  <a href="/?led=off"><button class="button2">Presence</button></a><a href="/?led2=on"><button class="button3">Absence</button></a><div>
  <p <h1>____________________________</h1></p>
  <p <h1><B>Demande exceptionnelle</B></h1></p>
  <form action=”” method=”POST”>
      <p align="center" style="margin-bottom: 0cm; line-height: 100%">
    <input type="text" id="name1" name="name1" required
       minlength="2" maxlength="2" size="3" value=''>
	   <label for="contactChoice1"> Degres_    </label>
	<input type="text" id="name2" name="name2" required
       minlength="1" maxlength="2" size="2" value=''>
       <label for="contactChoice1">Heure(s) </label>
      <p align="center" style="margin-bottom: 0cm; line-height: 100%"><button type="submit">Enregistrer</button><p/>
      <p>"""+excep+"""</p>
   </form>
   </div></p></body></html>"""
  return html
def exist():# 	choix du repertoire
  a=0
  b=0
  c=0
  d=0
  global rep # repertoire
  global ab # indice absence ou exception
  global av # indice avant exception
  ab=0
  rep1=''
  rep2=''
  rep3=''
  rep4=''
    f=open('p.txt','r')
    rep1='p'
    f.close
  except :
    pass
    f=open('t.txt','r')
    rep2='t'
    f.close
    print(rep2)
  except :
    pass
    f=open('a.txt','r')
    rep3='a'
    f.close
  except :
    pass
    f=open('e.txt','r')
    rep4='e'
    f.close
  except :
    pass
  if rep1=='p'and a==0: # fichier presence
    a=1
    b=0
    c=0
    d=0
    rep='p'
    ab=1
    if rep2=='t':
	      os.remove('t.txt')
      except :
        pass
    if rep3=='a':
        os.remove('a.txt')
      except :
        pass
    if rep4=='e':
        os.remove('e.txt')
      except :
        pass
  if rep2=='t'and b==0: # fichier travail
    a=0
    b=1
    c=0
    d=0
    rep='t'
    ab=0
    if rep1=='p':
	      os.remove('p.txt')
      except :
        pass
    if rep3=='a':
        os.remove('a.txt')
      except :
        pass
    if rep4=='e':
        os.remove('e.txt')
      except :
        pass
  if rep3=='a'and c==0: # fichier absence
    a=0
    b=0
    c=1
    d=0
    ab=2
    if rep2=='t':
	      os.remove('t.txt')
      except :
        pass
    if rep1=='p':
        os.remove('p.txt')
      except :
        pass
    if rep4=='e':
        os.remove('e.txt')
      except :
        pass
  if rep4=='e'and d==0: # fichier exception
    a=0
    b=0
    c=0
    d=1
    ab=3
    if rep2=='t':
      av=rep2
        os.remove('t.txt')
      except :
        pass
    if rep3=='a':
      av=rep3
        os.remove('a.txt')
      except :
        pass
    if rep1=='p':
      av=rep1
        os.remove('p.txt')
      except :
        pass
def timep():
    NTP_QUERY = bytearray(48)
    NTP_QUERY[0] = 0x1b
    addr = socket.getaddrinfo(host, 123)[0][-1]
    s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
    s.settimeout(1)
    res = s.sendto(NTP_QUERY, addr)
    msg = s.recv(48)
    s.close()
    val = struct.unpack("!I", msg[40:44])[0]
    return val - NTP_DELTA
  except:
      NTP_QUERY[0] = 0x1b
      addr = socket.getaddrinfo(hosts, 123)[0][-1]
      s.settimeout(1)
      msg = s.recv(48)
      s.close()
    except:
      pass
def settimep():
  t = timep()
  tm = utime.localtime(t)
  tm = tm[0:3] + (0,) + tm[3:6] + (0,)
  machine.RTC().datetime(tm)
while True :
  dat=[]
  aa=0
  settimep()
  u=utime.localtime()
  exist()
  if ab==0 or ab==1: # si presence ou travail
    with open(rep+str(u[6])+'.txt') as file: # lecture fichier suivant le jour ( 0 = lundi )
      for line in file.read().strip().split("\r"):
        aa=aa+1
        liste = [int(c) for c in line.strip().split(",")]
        dat.append(liste)
    ti=(u[3]*60)+(u[4]) # actuel heure*60 + minutes
    #tb=(u[3]*60)+(u[4]+2) # actuel heure*60 + minutes +2
    for i in range(aa):
		  ta=(dat[i][0]*60)+dat[i][1] # heure*60 + minutes ( fichier du jour )
		  if ti >= ta: # si heure du actuel est superieur ou egale heure du fichier
		    tempf=float(dat[i][2]) # temperature demandee
  if ab==2: # si absence
    tempf=16
  if ab==3: # si exception
    if ind == 0:
      with open('e.txt') as file: # lecture fichier exception
		    dat.append(liste)
      ta=(dat[0][0]*60) # heure*60 ( fichier d exception )
      tempf=int(dat[0][2]) # temperature demandee
      ind = 1
      ja= u[6] # garde jour actuel
      tah=ta/1440
      if tah >= 0 :
        j = int(tah) # nombre de jours
        jh=ta-(1440*j) # reste de temps - nombre de jours
        jh=ta # nombres de minutes
        j=j+ja # jour actuel + nombre de jours
    if j == u[6] and jh == u[3] :
      ind=0
      os.remove('e.txt')
      o=open(av+'.txt','w')
      o.write('')
      o.close()
  tem=float(temp())
  if tem < (tempf - 0.25):
    led.value(1)
    rel.value(1)
    g=1
    print('allumer')
    h1='#E12A1E'
  if tem < (tempf +0.25) and g==1:
	  pass
    led.value(0)
    rel.value(0)
    g=0
    print('eteint')
    h1='#0F3376'
  conn, addr = s.accept()
  request = conn.recv(1024)
  request = str(request)
  na=request.find('?')
  led_on = request.find('/?led=on')
  led_off = request.find('/?led=off')
  led2_on = request.find('/?led2=on')
  if request[na+1:na+6]=='name1' :
    deg=request[na+7:na+9]
    heu=request[na+16:na+18]
    excep=(deg+' degres '+heu+' heures')
    ab=3
    f=open('e.txt','w')
    f.write(heu+','+deg)
    f.close()
  if led_on == 6:
    ab=0
    f=open('t.txt','w')
    f.write(' ')
    f.close()
  if led_off == 6:
    ab=1
    f=open('p.txt','w')
    f.write(' ')
    f.close()
  if led2_on == 6:
    ab=2
    f=open('a.txt','w')
    f.write(' ')
    f.close()
  response = web_page()
  conn.send('HTTP/1.1 200 OK\n')
  conn.send('Content-Type: text/html\n')
  conn.send('Connection: close\n\n')
  conn.sendall(response)
  conn.close()
bellad
Re: where to place the web request ?
Post by bellad » Thu Jan 16, 2020 2:46 pm
thank , can you be more specific
I forgot to say , i work with esp8266 ( esp12 ) ,not much sram !!
i think , if there is a connection request then he sends , else he pass
but how to ??
bellad
Post by bellad » Fri Jan 17, 2020 9:28 am
sorry , I am not strong enough to understand
the script is blocked by waiting for a connection
let's take a simpler example :
original :
import socket
def log(msg):
    print(msg)
def do_connect():
    if not sta_if.isconnected():
        log('connecting to network...')
        sta_if.active(True)
        sta_if.connect('<SSID>', '<PASSWORD>')
        while not sta_if.isconnected():
            pass
    log('network config:'+str( sta_if.ifconfig()))
def start_myserver():
    log('start server method')
    addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
    s = socket.socket()
    s.bind(addr)
    s.listen(1)
    log('listening on'+str( addr))
        cl, addr = s.accept()
        log('client connected from'+str(addr))
        cl.send(html)
        cl.close()
#main part
html = """<!DOCTYPE html>
<html>
    <head> <title>ESP8266</title> </head>
    <body>
        Bonjour
    </body>
</html>
I would like to display the word 'good' in the loop away
as in my example, which doesn't work :
import socket
def log(msg):
    print(msg)
def do_connect():
        sta_if.active(True)
            pass
    s = socket.socket()
    s.bind(addr)
    s.listen(1)
        if s.accept() == True :
          cl.send(html)
          cl.close()
          print('good')
#main part
<html>
    <body>
        Bonjour
    </body>
</html>
I try to make myself understood with my English translated by google !!
thank you
namanjohnson101
Post by namanjohnson101 » Sun Jan 19, 2020 9:11 am
jedie wrote:
Thu Jan 16, 2020 3:13 pm
My minimal_webserver.py is also for ESP8266 ;)
Another example can you find here: viewtopic.php?f=16&t=7467
hello,
thanks for sharing this is helpful or informative for me kamukta
bellad
Post by bellad » Mon Jan 27, 2020 9:34 am
for me not enough memory :oops:
jedie
Post by jedie » Mon Jan 27, 2020 3:35 pm
ESP8266 ?
See: viewtopic.php?f=2&t=7345 ... in the end: You have to move the mpy scripts into firmware as frozen modules.
bellad
Post by bellad » Tue Jan 28, 2020 2:27 pm
yes ESP8266 ( ESP12F )
thank , I will try ,but it is not won , because I have to translate
bellad
Post by bellad » Tue Feb 04, 2020 8:40 am
hi , i try , but no work
can you help please
my code for esp8266
it's for ' apl2 ' no blocking ' apl1 '
and if i call apl2 ( web ) no blocking apl1
it'possible ??
import utime
import uasyncio as asyncio
g=0
except:
  import socket
except:
  import struct
jr=('Lundi','Mardi','Mercredi','Jeudi','Vendredi','Samedi','Dimanche','Lundi','Mardi','Mercredi','Jeudi','Vendredi','Samedi','Dimanche')
s.bind(('', 80))
s.listen(5)
ex=''
h1='#0F3376'
ab=0
m=0
mm=0
ind=0
rep='t'
def temp():
  li=l.read()
  ts=bmp.raw_values
  temper=ts[0]
def web_page():
  <p>"""+ddt+"""</p>
      <p>"""+ex+"""</p>
   </form>
  return html
def timep():
    NTP_QUERY[0] = 0x1b
    s.settimeout(1)
    msg = s.recv(48)
    s.close()
  except:
      NTP_QUERY[0] = 0x1b
      s.settimeout(1)
      msg = s.recv(48)
      s.close()
    except:
      pass
def settimep():
  t = timep()
async def apl1():
  while True :
    dat=[]
    aa=0
    settimep()
    u=utime.localtime()
    if ab != 3:
      ind=0
      ex=''
          aa=aa+1
          dat.append(liste)
      for i in range(aa):
      tempf=16
      if ind == 0:
        hac=u[3]*60
        mac=u[4]
        ma=str(int(float(mac)))
        ht=hac+mac
        ta=int(heu)*60 # heure*60 ( fichier d exception )
        tempf=float(deg) # temperature demandee
        ind = 1
        tah=int(ta/1440)
        if tah !=0 :
          j = tah # nombre de jours
          jh=int(((ta-(1440*j))+ht)/60) # reste de temps - nombre de jours
          j=j+ja
          jh=int(heu) +(hac/60) #nombres d heures
          j=ja # jour actuel
        ex= 'se termine '+jr[j]+' '+str(int(jh))+' h '+ ma
      if j == u[6] and jh == u[3] and mac == u[4]:
        ind=0
        if av=='t':
          ab=0
        if av=='p':
          ab=1
        if av=='a':
          ab=2
        rep=av
    tem=float(temp())
      led.value(1)
      rel.value(1)
      g=1
      print('allumer')
      h1='#E12A1E'
	    pass
      led.value(0)
      rel.value(0)
      g=0
      print('eteint')
      h1='#0F3376'
async def apl2():
      ab=3
      av=rep
      rep='e'
    if led_on == 6:
      rep='t'
      ab=0
    if led_off == 6:
      rep='p'
      ab=1
    if led2_on == 6:
      rep='a'
      ab=2
    conn.close()
loop.call_soon(apl1)
loop.call_soon(apl2)
loop.run_forever()
