ModuleNotFoundError: No module named 'pyb'
spoetnic
Post by spoetnic » Tue Feb 11, 2020 2:19 pm
Hello, I'm just new to micropython and I just managed to get python installed on microsoft code.
Now I've connected my pyboard 1.1 and try to run a default program.
The first error I hit is: ModuleNotFoundError: No module named 'pyb'
I hope someone can help solving this? Thanks.
Re: ModuleNotFoundError: No module named 'pyb'
Post by dhylands » Tue Feb 11, 2020 5:45 pm
Which board are you using? The pyb module exists on the stm32 port, and doesn't exist on the ESP32 and ESP8266 ports.
The general preference is to use the machine module where possible.
spoetnic
Post by spoetnic » Thu Feb 13, 2020 8:45 am
Hi, I'm using the pyboard 1.1. So this is with the STM32405RG. I'm trying to upload an code to the board from VSCODE. The board is connected, but when trying to RUN it says:
PS C:\Users\Marc Frim> & "C:/Users/Marc Frim/AppData/Local/Programs/Python/Python38-32/python.exe" "c:/Users/Marc Frim/.vscode/extensions/rt-thread.rt-thread-micropython-1.0.7/microExamples/examples/03.board/5.pyboard/blink.py"
File "c:/Users/Marc Frim/.vscode/extensions/rt-thread.rt-thread-micropython-1.0.7/microExamples/examples/03.board/5.pyboard/blink.py", line 2, in <module>
Post by jimmo » Thu Feb 13, 2020 12:23 pm
It looks like it's trying to run in regular Python (i.e. CPython) rather than on the pyboard.
spoetnic
Post by spoetnic » Tue Feb 18, 2020 11:34 am
Indeed I did install python, RT-Thread MicroPython and Pymakr into VS code. Still I'm getting this error: ModuleNotFoundError: No module named 'pyb' when pressing RUN.
fillofonta
Post by fillofonta » Thu Jul 30, 2020 7:00 am
i'm having a similar problem with pycharm, the error is the following :
DEPRECATION: The -b/--build/--build-dir/--build-directory option is deprecated. pip 20.3 will remove support for this functionality. A possible replacement is use the TMPDIR/TEMP/TMP environment variable, possibly combined with --no-clean. You can find discussion regarding this at https://github.com/pypa/pip/issues/8333.
ERROR: Could not find a version that satisfies the requirement pyb (from versions: none)
ERROR: No matching distribution found for pyb
I am able to install other libraries of micropython
Post by jimmo » Thu Jul 30, 2020 9:20 am
You don't need to pip install the pyb module, it's included in the firmware.
fillofonta
Post by fillofonta » Thu Jul 30, 2020 9:22 am
how do i use it then? when i write it i get Unresolved reference 'pyb'
Post by Roberthh » Thu Jul 30, 2020 9:40 am
The pyb module only exists on Pyboard hardware. Which board are you using?
fillofonta
Post by fillofonta » Thu Jul 30, 2020 9:56 am
i am using a nucleo-f767zi, but shouldn't be able to mimport it anyway and not be able af use it??
