async read keypressed in terminal
VladVons
Post by VladVons » Fri Feb 14, 2020 6:57 pm
i want to read in terminal keypressed while http server is running.
please hint me
Re: async read keypressed in terminal
Post by jimmo » Sat Feb 15, 2020 5:02 am
You can use select or poll on sys.stdin to see if there are characters available (which you can then read using sys.stdin.read).
More info here: viewtopic.php?f=18&t=6954&p=39455
VladVons
Re: async read keypressed in terminal [SOLVED]
Post by VladVons » Sat Feb 15, 2020 8:27 am
thanks jimmo
import uasyncio as asyncio
import sys
import select
async def Task1():
    print('Task1')
    await asyncio.sleep(1)
async def Task2():
    await asyncio.sleep(0.1)
    while sys.stdin in select.select([sys.stdin], [], [], 0)[0]:
        ch = sys.stdin.read(1)
        print('none block input char', ch)
loop.create_task(Task1())
loop.create_task(Task2())
loop.run_forever()
