Booting board at 20mhz.
I know how to change the board frequency after its booted. But how do i make it boot up at 20mhz?
Re: Booting board at 20mhz.
If you can do this with firmware written in C using the IDF directly, then you can do this in MicroPython if you build your own firmware. Likely it's an sdkconfig option?
You should be able to do that yes
