Building micrpython on unix
ndshah88
Post by ndshah88 » Wed Mar 18, 2020 1:32 pm
I am trying to build micropython on unix. Here is the link I follow to do that:
https://github.com/micropython/micropyt ... ed#mac-osx
However, while I try to make axtls I get an error. The error is attached here.
Can someone guide on what I am missing?
Thanks in advance
Screenshot 2020-03-18 at 6.56.32 PM.jpg (65.98 KiB) Viewed 1426 times
Re: Building micrpython on unix
Post by dhylands » Wed Mar 18, 2020 10:32 pm
The section on building micropython lists some external dependencies which are required:
https://github.com/micropython/micropyt ... pendencies
Based on the error messages you're reporting, you're missing at least pkg-config and libffi (both mentioned in the external dependencies section).
ndshah88
Post by ndshah88 » Fri Mar 20, 2020 7:08 am
Thank you.
We will check that out and come back to this post shortly.
