Confusion about micropython.const
Walkline
Post by Walkline » Thu Mar 19, 2020 1:44 pm
Here's the sample code:
from micropython import const
class a(object):
    test = const(0x1)
class b(object):
    test = 0
And here is the result:
  File "<stdin>", line 4, in b
SyntaxError: can't assign to expression
According to the documents about micropython.const
Constants declared this way are still accessible as global variables from outside the module they are declared in.
It is a global variable, but it is also a class member constant. Why does it affect member variables of other classes?
fstengel
Re: Confusion about micropython.const
Post by fstengel » Thu Mar 19, 2020 4:26 pm
Look there: http://docs.micropython.org/en/latest/r ... eclaration
As far as I can tell, when you write foo=const(42) then foo is not a variable but behaves as if, as compile time, it is replaced by 42. So your code would be seen as:
class a(object):
    test = const(0x1) # from now on test is a shortcut for 0x1
class b(object):
    0x1 = 0 # and here it fails: test has been replaced by its "value"
Walkline
Post by Walkline » Thu Mar 19, 2020 6:25 pm
Thanks fstengel, that's uh.....amazing
And then I have second question
ONE = 1
TWO = 2
COMPILED = const(ONE | TWO)
In this way, it's still got exception, according to you link
The argument to const() may be anything which, at compile time, evaluates to an integer e.g. 0x100 or 1 << 8.
Is "anything" excluded variables?
Post by Roberthh » Thu Mar 19, 2020 7:26 pm
The reason: variable assignment does not happen at compile time. It happens when the code is executed.
In comparison, the following works:
ONE = const(1)
TWO = const(2)
Note: You do not have to import const.
Walkline
Post by Walkline » Fri Mar 20, 2020 3:52 am
Thanks Robert, this is helpful for me, thanks again :D
