ubluetooth: ability to set MTU after connecting to peripheral device?
pyrocket
Post by pyrocket » Thu Mar 26, 2020 6:42 pm
New to micropython & the ESP32, somewhat familiar with BLE. Using the ubluetooth library on the ESP32, I've been able to successfully gap_scan, gap_connect and gattc_read (mostly). However, on a read, the full payload I am expecting is larger than the default MTU. I found that the 'rxbuf' can be configured and tried setting that to a few different values up to 517 (the max if I understand correctly), but this didn't change the data returned.
I have been able to successfully connect & read from this other peripheral using the nRF Connect app on Android, but with the same results until I configured a larger MTU size. As I understand, this actually triggers a MTU exchange request to the gatt server on the peripheral, which then responds with a MTU exchange response.
Is there a way to exchange a new MTU in micropython?
Re: ubluetooth: ability to set MTU after connecting to peripheral device?
Post by jimmo » Thu Mar 26, 2020 11:48 pm
Unfortunately right now there's no Python-level API for this. It's on the TODO list: https://github.com/micropython/micropython/issues/5186
If you're happy to build your own firmware, then you can modify MP_BLUETOOTH_DEFAULT_ATTR_LEN in extmod/modbluetooth.h or modify the call to ble_att_set_preferred_mtu in extmod/nimble/modbluetooth_nimble.c
Post by jimmo » Thu Mar 26, 2020 11:49 pm
If you have thoughts on how this should work, please comment on that bug.
Some ideas:
- If you modify hte rxbuf size, it should also implicitly set the mtu to be at least that big?
- Add an explicit "set MTU" function to the BLE type.
pyrocket
Post by pyrocket » Fri Mar 27, 2020 4:37 pm
Thanks for the response @jimmo. Might be fun to give building MP myself a try, I'll post up if I have any success.
If I get into the weeds enough to have any worthwhile suggestions I'll definitely add a comment. Without being too familiar with the internals, as a user of the API I would either prefer an explicit function or perhaps a MTU arg on the gap_connect function, which would immediately set the MTU on successful connection. The arg 'rxbuf' isn't readily apparent as equivalent to MTU to somebody new to the scene.
