LCD st7920 on esp8266 ModeMcu v3 Lolin
piterski
Post by piterski » Mon Apr 06, 2020 12:02 pm
helow
I'm trying to run st7920 on NodeMcu v3 Lolin. I chose it because it has 5V
most likely the system has SPI("GPIO_8 MOSI" ," GPIO_6 CLK") and HSPI("GPIO_13 MOSI" GPIO_14 CLK")
I try like mcauser
import st7920
spi = SPI(1)
screen = st7920.Screen(slaveSelectPin=Pin(4), resetDisplayPin=Pin(5))
screen.plot(5, 5)
screen.plot(5, 5) evokes error
  File "<stdin>", line 1 in <module>
  File "canvas.py", line 2 in raiseError
 NotImplemementedError:
Where should I start ?
piterski
Re: LCD st7920 on esp8266 ModeMcu v3 Lolin
Post by piterski » Fri Apr 10, 2020 8:54 am
On my Raspberry Pi works OK!
import spidev
class ST7920:
	def __init__(self):
		self.spi = spidev.SpiDev()
		self.spi.open(0,0)
		self.spi.cshigh = True # use inverted CS
		self.spi.max_speed_hz = 1800000 # set SPI clock to 1.8MHz, up from 125kHz
		self.send(0,0,0x30) # basic instruction set
		self.send(0,0,0x30) # repeated
		self.send(0,0,0x0C) # display on
		self.send(0,0,0x34) #enable RE mode
		self.send(0,0,0x34)
		self.send(0,0,0x36) #enable graphics display
		self.set_rotation(0) # rotate to 0 degrees
	def send(self, rs, rw, cmds):
		if type(cmds) is int: # if a single arg, convert to a list
			cmds = [cmds]
		b1 = 0b11111000 | ((rw&0x01)<<2) | ((rs&0x01)<<1)
		bytes = []
		for cmd in cmds:
			bytes.append(cmd & 0xF0)
			bytes.append((cmd & 0x0F)<<4)
		return self.spi.xfer2([b1] + bytes)
On esp8266 no module spidev error spi.xfer2. Can i replace it spi = hspi or self.spi = SPI(-1, baudrate=baudrate, polarity=polarity, phase=phase, sck=sck, mosi=mosi, miso=miso)
piterski
Post by piterski » Mon Apr 13, 2020 6:32 pm
On Raspberry Pi works ok
I replaced cod python2 on python3
I'm using the function plot(x,y) to draw a point x,y
import spidev
class ST7920:
    def __init__(self):
        self.spi.open(0, 0)
        self.send(0, 0, 0x30)  # basic instruction set
        self.send(0, 0, 0x30)  # repeated
        self.send(0, 0, 0x0C)  # display on
        self.send(0, 0, 0x34)  # enable RE mode
        self.send(0, 0, 0x36)  # enable graphics display
        self.width = 128
        self.height = 64
        self.clear()
#        self.plot(0,63)
        self.redraw()
            cmds = [cmds]
        b1 = 0b11111000 | ((rw & 0x01) << 2) | ((rs & 0x01) << 1)
        bytes = []
        for cmd in cmds:
            cmd = int(cmd)
            bytes.append((cmd & 0x0F) << 4)
    def plot(self, x, y):
        if x < 0 or x >= self.width or y < 0 or y >= self.height:
            return
        self.fbuff[y][x // 8] |= 1 << (7 - (x % 8))
    def clear(self):
        self.fbuff = [[0] * (128 // 8) for i in range(64)]
    def redraw(self, dx1=0, dy1=0, dx2=127, dy2=63):
        for i in range(dy1, dy2 + 1):
            self.send(0, 0, [0x80 + i % 32, 0x80 + ((dx1 // 16) + (8 if i >= 32 else 0))])
            self.send(1, 0, self.fbuff[i][dx1 // 8:(dx2 // 8) + 1])
SPI sends packets in the format
([248, 144, 240, 128, 128])
([250, 128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 16])
Now I would like to use SPI.write on micropython
Post by jimmo » Tue Apr 14, 2020 5:45 am
yes, you will have to use machine.SPI instead. xfer2 looks to be the same as the write() method on machine.SPI.
piterski
Post by piterski » Wed Apr 15, 2020 7:36 am
Works on esp8266 NodeMcu V3. Without additional power supply.
The solution is:
change int SPI and send to SPI
spi = SPI(1, baudrate=1800000, polarity=0, phase=0
return self.spi.write(bytearray([b1] + bytes))
Next problem is Fonts. I can upload a maximum of 2 fonts. And I lack memory.
A very long time ago I did a project on Audrino Uno. I used 3 fonts and 4 Graphic Icon 26x26 and 10szt 18b20 and keyPad.
Works until today. I used u8g2lib in Audrino
My question is how to optimize in micropython the font table as much as possible so that it takes as little memory as possible
piterski
Post by piterski » Thu May 07, 2020 7:25 am
Hello.
Maybe someone will need this information
I replaced the double list "bytearray" on a single list "int". About 10 times less space
I launched the alpha version. Its working.
If I develop a project, I will make it available
