Tinyweb and XMLHttpRequest
Semicolonist
Post by Semicolonist » Thu Apr 16, 2020 6:02 pm
I'm using Tinyweb library on ESP32. I need to send JSON from website to ESP32 and from ESP32 to website.
So that's my code from website:
For json request:
        var xhttpData = new XMLHttpRequest();
        xhttpData.open('POST', 'DATAJson', true);
        xhttpData.setRequestHeader("Content-Type", "application/json");
        xhttpData.onreadystatechange = function()
            if (xhttpData.readyState === 4)
                var DATAJson = xhttpData.response;
                console.log(DATAJson)
        xhttpData.send();
For json send:
            var xhttp2 = new XMLHttpRequest();
            xhttp2.open('POST', 'DATAJsonRecv', true);
            xhttp2.setRequestHeader("Content-Type", "application/json");
            xhttp2.onreadystatechange = function()
                if (xhttp2.readyState === 4)
                    alert("Data sent");
            xhttp2.send('{"JsonTestValue":5}');
And that's my code on ESP32 (routes part):
	@app.route('/DATAJson')
	async def index(request, response):
    		await response.send_file('data.json')
    	@app.route('/DATAJsonRecv')
    		await print(request)
When I try to get JSON from ESP using website I get error 405.
But when I simply write an address 192.168.4.1:8081/DATAJson i get the text of json in web browser. So I guess that code on ESP is correct.
When I try to send JSON to ESP I don't see any reaction.
What I'm doing wrong?
Re: Tinyweb and XMLHttpRequest
Post by jimmo » Fri Apr 17, 2020 3:40 am
One difference is that you're doing a GET request from the browser, but the javascript is doing a POST.
I don't know enough about TinyWeb but that might at least give you something to test?
"await print" will not work. You can only await an async function.
Semicolonist
Post by Semicolonist » Fri Apr 17, 2020 11:49 am
It helped. I tested it and I changed:
to:
xhttpData.open('GET', 'DATAJson', true);
And it's working.
But to send JSON from website to ESP I need POST method. I get error 405 on the website so I tried to add "methods" to route on ESP like that:
    	@app.route('/DATAJsonRecv', methods = ['POST'])
    		print(request.read_parse_form_data())
    		await response.start_html()
    		await response.send("201")
And now I don't have error 405 and it seems working but I can't read my data from request. From print I get "<generator object 'read_parse_form_data' at 3ffc8260>".
In documentation I found:
read_parse_form_data() - By default (again, to save CPU/memory) tinyweb doesn't read form data. You have to call it manually unless you're using RESTApi. Returns dict of key / value pairs.
I need basic string to json.loads() it. How can I get string from this POST data?
Post by jimmo » Fri Apr 17, 2020 12:22 pm
I don't know much about tinyweb, but based on that output, I would assume that it should be
print(await request.read_parse_form_data())
(Note "print(await foo())" is not the same as "await print(foo())".
Semicolonist
Post by Semicolonist » Fri Apr 17, 2020 1:09 pm
Noted ;)
I changed it, now output is "{}"
EDIT:
I added:
max_body_size = 2048, save_headers = ["Content-Length","Content-Type"], allowed_access_control_headers = ["Content-Length","Content-Type"]
to route configuration and now everything works fine.
Thank you for all your help!
