[NUCLEO_F413ZH] - Use FS on USB OTG
srednax
Post by srednax » Mon Apr 20, 2020 9:13 am
Hi there,
I recently purchased a NUCLEO_F413ZH, which has a user USB port on one end of the board. Does the current release version of µPython support loading scripts from a connected USB stick through an OTG adapter? If so, what filesystem should it be formatted to?
I tried connecting a 32GB USB stick to it, which is FAT32 formatted. I tried with something like
os.listdir("/")
but that only showed me
['Flash']
and no additional file systems present.
Is there a way to make this work?
TIA!
Re: [NUCLEO_F413ZH] - Use FS on USB OTG
Post by jimmo » Mon Apr 20, 2020 12:32 pm
Unfortunately no, sorry. Although the hardware supports it, there's currently no support in MicroPython for USB host mode (or OTG), only device mode.
I believe some work was done a long time ago, but the most recent mention I can find is: https://github.com/micropython/micropyt ... -503102537
srednax
Post by srednax » Mon Apr 20, 2020 12:43 pm
Thank you. That is a shame. I wonder how hard it would be to add it. I may look into it.
Post by jimmo » Mon Apr 20, 2020 12:46 pm
There's been occasional discussion of moving the STM32 port over to use TinyUSB instead of the current implementation based loosely on the STM HAL. This would certainly make adding host support easier.
