[Windows / Linux] Error: 'module' object has no attribute 'Pin'
Hitman1O1
Post by Hitman1O1 » Sat Apr 25, 2020 4:37 pm
I want to develop Micro-Python for my microcontroller and figured it could be useful to be able to run it locally (i.e. on my PC) too.
So I built Micro-Python for Windows (https://github.com/micropython/micropyt ... ts/windows) using Microsoft Visual Studio 2019, which was successful. I can run `.\micropython` and use the Micro-Python interpreter. I can also `import machine` without any problems.
But when I try to use any machine module, e.g. `pin = machine.Pin(0, PIN.IN)` I get errors like this:
It seems like the machine module is entirely empty.
I tried building and using it on my Ubuntu laptop too, with exactly the same result.
Is something broken on my installs? Or are the Windows/Linux Micro-Python builds not supposed to be able to do much?
Online
kevinkk525
Re: [Windows / Linux] Error: 'module' object has no attribute 'Pin'
Post by kevinkk525 » Sat Apr 25, 2020 5:16 pm
The Unix port of micropython does not have that because it has no hardware pins.
If you want to use the Unix build for debugging, you will have to provide a "fake" machine module implementation.
Kevin Köck
Post by jimmo » Sun Apr 26, 2020 3:14 am
Yeah, like Kevin says, there's no Pin class because what would it mean for a Windows / Linux computer to control a pin?
Here is an example Python implementation though that provides access to hardware GPIO (e.g. on Linux running on Raspberry Pi). https://github.com/micropython/micropyt ... ine/pin.py
Hitman1O1
Post by Hitman1O1 » Sun Apr 26, 2020 5:22 pm
Thank you for your replies.
I figured al the in-out related functions were already faked. I guess there is only the 'plain' Micro-Python executable then.
No such 'dry' implementations exist already?
Post by jimmo » Tue Apr 28, 2020 3:04 am
What does "dry" mean here?
Is https://github.com/micropython/micropyt ... ine/pin.py not what you're looking for?
