uasyncio - How detect the end task in another task.
prem111
Post by prem111 » Wed Jun 17, 2020 6:28 pm
How to detect the end or „is running” of a task that is running in another task. How to detect termination or running task: some_function.run() ?
async def service1():
    ap_task = uasyncio.create_task(some_function.run())
    await uasyncio.sleep(0)
async def main():
    tasks = (service1, service2)
        res = await uasyncio.funcs.gather(*tasks, return_exceptions=False)
uasyncio.run(main())
kevinkk525
Re: uasyncio - How detect the end task in another task.
Post by kevinkk525 » Wed Jun 17, 2020 6:30 pm
You currently can't because it is not implemented in the Task class.
But you can gather multiple tasks, that would show their termination.
Kevin Köck
prem111
Post by prem111 » Wed Jun 17, 2020 6:36 pm
How to do it ?
kevinkk525
Post by kevinkk525 » Wed Jun 17, 2020 8:57 pm
it works just like in CPython but you can take a look here: https://github.com/peterhinch/micropyth ... UTORIAL.md
Kevin Köck
Post by pythoncoder » Thu Jun 18, 2020 5:13 am
        [code]res = await uasyncio.funcs.gather(*tasks, return_exceptions=False)
This line should read
res = await uasyncio.gather(*tasks, return_exceptions=False)
Gather is described here.
I'm not entirely sure what you're trying to achieve, though. Consider the following:
import uasyncio as asyncio
async def foo():
   for _ in range(5):
       # do something
       await asyncio.sleep_ms(100)  # slow coro
task = asyncio.create_task(foo())
async def bar():
   await asyncio.sleep(1)
   # You can await task if you want to pause until it's run
   # Or test its status as follows
       await asyncio.wait_for_ms(task, 1)
   except asyncio.TimeoutError:
       print('foo is running')
      print('foo has stopped')
asyncio.run(bar())
It's perhaps not ideal, but it works here on a Pyboard. See for reference
