"Empty" TypeError
Ricardo
"Empty" TypeError
Post by Ricardo » Mon Jun 22, 2020 4:10 pm
Hi there!
The code below runs fine on CPython (versions 2.7.16, 3.4.10, 3.7.0, ...), but produces a "TypeError" on MicroPython (ESP32 firmware esp32-idf3-20200618-unstable-v1.12-554-gce02d5e34):
class Cfg(dict):
    def __init__(self, default={}):
        self.update(default)
cfg = Cfg(default={"rate": 30})
print(cfg)
Running the code on CPython, the result is:
{'rate': 30}
Running the same code on Micropython REPL, the result is:
  File "<stdin>", line 5, in <module>
  File "<stdin>", line 3, in __init__
TypeError:
Is this a known bug / limitation of MicroPython?
Is there any suggested workaround?
Thanks!
Ricardo
Re: "Empty" TypeError
Post by Ricardo » Mon Jun 22, 2020 6:46 pm
Oddly enough, this code works on MicroPython:
class Cfg(dict):
    pass
cfg = Cfg()
cfg.update({"rate": 30})
print(cfg)
The result is, as expected:
{'rate': 30}
Now I'm using something like this as a workaround, but I wonder if this issue is a bug in MicroPython...
Christian Walther
Post by Christian Walther » Mon Jun 22, 2020 8:28 pm
It’s probably an instance of the vaguely documented known limitation “subclassing native classes is not fully supported in MicroPython” (http://docs.micropython.org/en/latest/g ... ubclassing).
Ricardo
Post by Ricardo » Mon Jun 22, 2020 9:10 pm
Looks like you've hit the target! Thanks, Christian!
SpotlightKid
Post by SpotlightKid » Mon Jun 22, 2020 9:33 pm
You can always delegate instead of inheriting:
class Cfg:
        self._dict = {}
        self._dict.update(default)
    def __getattr__(self, name):
        return getattr(self._dict, name)
    def __getitem__(self, name):
        return self._dict[name]
    def __repr__(self):
        return repr(self._dict)
    # plus any other special methods you need
print(cfg)
Ricardo
Post by Ricardo » Mon Jun 22, 2020 9:46 pm
True! It is a bigger workaround, though, but one to keep in mind. Thanks!
