What does `\*` mean in `pyb.mount` documentation?
hlovatt
Post by hlovatt » Tue Jun 23, 2020 2:53 am
Hi All,
In the documentation for `pub.mount` the argument list contains `\*`, what does this mean?
The actual line is:
mount(device, mountpoint, \*, readonly=False, mkfs=False)
I'm assuming this is a typo; and poking around with the REPL makes me think it should be `/, *`.
Anyone know the real answer?
Thanks,
Howard.
Re: What does `\*` mean in `pyb.mount` documentation?
Post by dhylands » Tue Jun 23, 2020 8:53 pm
The convention seems to be that \* is used to document the divide between required positional arguments and optional (typically keyword) arguments.
You can see other examples here: http://docs.micropython.org/en/latest/l ... e.SPI.init
My understanding is that arguments after the \* must be provided by using keywords.
hlovatt
Post by hlovatt » Wed Jun 24, 2020 1:21 am
Thanks for your response
The notation is `/, *` not `\*`, for dividing between positional and nominal, i.e.:
def f(positional, /, either_positional_or_nominal, *, nominal)
So my reading was that `\*` was a typo, and `\, *` was intended, i.e. the transition between positional and nominal as you say.
Using `/` to mean positional is relatively new, whereas the `*` to mean nominal has been around for a while. Therefore it could be that `\*` is a typo for `*` (because when written `\` didn't exist, or it was intended that before `*` you could use either positional or nominal). However when playing with REPL it seems that the parameters must be positional before `\*`, therefore I was guessing that the best modern substitution is `/, *`.
I'm asking the question because I'm trying to write a typeshed for the PyBoard for the MicroPython plugin for PyCharm, hence I was hoping for a definitive answer rather than me trying to reverse engineer via the REPL!
Post by pythoncoder » Wed Jun 24, 2020 10:56 am
My understanding is that the only legal Python syntax is * meaning that subsequent args are keyword-only. I have no idea why the docs have \.
def foo(x, *, y):
    print(x, y)
foo(1, y = 2)  # Works
foo(1, 2)  # Will fail
hlovatt
Post by hlovatt » Thu Jun 25, 2020 12:07 am
Thanks for the reply.
Later versions of Python support `/`, it's https://www.python.org/dev/peps/pep-0570/. It's useful in the typeshed I'm writing since PyCharm is almost certainly running on a later version of Python. Of course the typeshed isn't downloaded to the PyBoard, and therefore not relevant that MicroPython doesn't understand it.
Don't suppose you know what the intent was? Don't feel that messing round with the REPL is the best way forward, its time consuming for a start and error prone.
Thanks again.
Post by Roberthh » Thu Jun 25, 2020 6:12 am
For me the '\*' just looks liken an unnecessary attempt to escape the '*' character. So it's a kind of typo.
hlovatt
Post by hlovatt » Thu Jun 25, 2020 7:53 am
Yeah, you could well be right. I was hoping someone would know definitively. Thanks.
Post by jimmo » Mon Jun 29, 2020 6:33 am
You're right. This apparently used to be necessary (e.g. see http://docs.micropython.org/en/v1.12/li ... #pyb.mount where it was generated correctly).
Raised https://github.com/micropython/micropython/issues/6209
