bme680 adafruit on pyboard
IHOXOHI
Post by IHOXOHI » Mon Jun 29, 2020 10:45 am
I try to use the bme680 sensor from adafruit...
After change i2c adress from 0x76 to 0x77 in the lib, I have this error: "OSError: I2C operation not supported"
The line which is implicated in the lib : "self._i2c.write(bytes([register & 0xFF]))"
I haven't find good reason for this problem, and I don't know what could produce this error...
Thanks for your help.
Re: bme680 adafruit on pyboard
Post by jimmo » Mon Jun 29, 2020 12:47 pm
Which library are you using?
IHOXOHI
Post by IHOXOHI » Mon Jun 29, 2020 2:03 pm
Thanks for your support Jimmo,
I use the adafruit_bme_680 library...
I have tried an other one wich concern directly micropython without success and I think that the adafruit lib is more closer of a success.
Thanks.
jcw
Post by jcw » Mon Jun 29, 2020 2:36 pm
Depending on how I2C addresses are exposed, the lower bit may not be an address bit - try 0x78.
(I haven't looked into the code or the BME680 ....)
Post by Roberthh » Mon Jun 29, 2020 2:45 pm
Below is the code of a modified adafruit driver. I just veruified that it returns reasonable results on Micropython. I adapted it initialy for the Pycom branch, but changed it now for micropython.org. call for instance with:
from pycom_bme680 import *
from machine import I2C,  Pin
i2c=I2C(-1, Pin(13), Pin(12))
bme=BME680_I2C(i2c)
bme.temperature
bme.humidity
bme.pressure
# The MIT License (MIT)
# Copyright (c) 2017 ladyada for Adafruit Industries
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
# THE SOFTWARE.
# We have a lot of attributes for this complex sensor.
# pylint: disable=too-many-instance-attributes
`adafruit_bme680` - Adafruit BME680 - Temperature, Humidity, Pressure & Gas Sensor
CircuitPython driver from BME680 air quality sensor
* Author(s): ladyada
import math
from micropython import const
from ubinascii import hexlify as hex
    import struct
except ImportError:
    import ustruct as struct
#    I2C ADDRESS/BITS/SETTINGS
_BME680_CHIPID = const(0x61)
_BME680_REG_CHIPID = const(0xD0)
_BME680_BME680_COEFF_ADDR1 = const(0x89)
_BME680_BME680_COEFF_ADDR2 = const(0xE1)
_BME680_BME680_RES_WAIT_0 = const(0x5A)
_BME680_REG_SOFTRESET = const(0xE0)
_BME680_REG_CTRL_GAS = const(0x71)
_BME680_REG_CTRL_HUM = const(0x72)
_BME280_REG_STATUS = const(0xF3)
_BME680_REG_CTRL_MEAS = const(0x74)
_BME680_REG_CONFIG = const(0x75)
_BME680_REG_STATUS = const(0x1D)
_BME680_REG_PDATA = const(0x1F)
_BME680_REG_TDATA = const(0x22)
_BME680_REG_HDATA = const(0x25)
_BME680_SAMPLERATES = (0, 1, 2, 4, 8, 16)
_BME680_FILTERSIZES = (0, 1, 3, 7, 15, 31, 63, 127)
_BME680_RUNGAS = const(0x10)
_LOOKUP_TABLE_1 = (2147483647.0, 2147483647.0, 2147483647.0, 2147483647.0, 2147483647.0,
                   2126008810.0, 2147483647.0, 2130303777.0, 2147483647.0, 2147483647.0,
                   2143188679.0, 2136746228.0, 2147483647.0, 2126008810.0, 2147483647.0,
                   2147483647.0)
_LOOKUP_TABLE_2 = (4096000000.0, 2048000000.0, 1024000000.0, 512000000.0, 255744255.0, 127110228.0,
                   64000000.0, 32258064.0, 16016016.0, 8000000.0, 4000000.0, 2000000.0, 1000000.0,
                   500000.0, 250000.0, 125000.0)
def _read24(arr):
    """Parse an unsigned 24-bit value as a floating point and return it."""
    ret = 0.0
    #print([hex(i) for i in arr])
    for b in arr:
        ret *= 256.0
        ret += float(b & 0xFF)
    return ret
class Adafruit_BME680:
    """Driver from BME680 air quality sensor
       :param int refresh_rate: Maximum number of readings per second. Faster property reads
         will be from the previous reading."""
    def __init__(self, *, refresh_rate=10):
        """Check the BME680 was found, read the coefficients and enable the sensor for continuous
           reads."""
        self._write(_BME680_REG_SOFTRESET, [0xB6])
        time.sleep(0.005)
        # Check device ID.
        chip_id = self._read_byte(_BME680_REG_CHIPID)
        if chip_id != _BME680_CHIPID:
            raise RuntimeError('Failed to find BME680! Chip ID 0x%x' % chip_id)
        self._read_calibration()
        # set up heater
        self._write(_BME680_BME680_RES_WAIT_0, [0x73, 0x64, 0x65])
        self.sea_level_pressure = 1013.25
        """Pressure in hectoPascals at sea level. Used to calibrate ``altitude``."""
        # Default oversampling and filter register values.
        self._pressure_oversample = 0b011
        self._temp_oversample = 0b100
        self._humidity_oversample = 0b010
        self._filter = 0b010
        self._adc_pres = None
        self._adc_temp = None
        self._adc_hum = None
        self._adc_gas = None
        self._gas_range = None
        self._t_fine = None
        self._last_reading = 0
        self._min_refresh_time = 1000 / refresh_rate
    @property
    def pressure_oversample(self):
        """The oversampling for pressure sensor"""
        return _BME680_SAMPLERATES[self._pressure_oversample]
    @pressure_oversample.setter
    def pressure_oversample(self, sample_rate):
        if sample_rate in _BME680_SAMPLERATES:
            self._pressure_oversample = _BME680_SAMPLERATES.index(sample_rate)
            raise RuntimeError("Invalid oversample")
    @property
    def humidity_oversample(self):
        """The oversampling for humidity sensor"""
        return _BME680_SAMPLERATES[self._humidity_oversample]
    @humidity_oversample.setter
    def humidity_oversample(self, sample_rate):
            self._humidity_oversample = _BME680_SAMPLERATES.index(sample_rate)
    @property
    def temperature_oversample(self):
        """The oversampling for temperature sensor"""
        return _BME680_SAMPLERATES[self._temp_oversample]
    @temperature_oversample.setter
    def temperature_oversample(self, sample_rate):
            self._temp_oversample = _BME680_SAMPLERATES.index(sample_rate)
    @property
    def filter_size(self):
        """The filter size for the built in IIR filter"""
        return _BME680_FILTERSIZES[self._filter]
    @filter_size.setter
    def filter_size(self, size):
        if size in _BME680_FILTERSIZES:
            self._filter = _BME680_FILTERSIZES[size]
            raise RuntimeError("Invalid size")
    @property
    def temperature(self):
        """The compensated temperature in degrees celsius."""
        self._perform_reading()
        calc_temp = (((self._t_fine * 5) + 128) / 256)
        return calc_temp / 100
    @property
    def pressure(self):
        """The barometric pressure in hectoPascals"""
        var1 = (self._t_fine / 2) - 64000
        var2 = ((var1 / 4) * (var1 / 4)) / 2048
        var2 = (var2 * self._pressure_calibration[5]) / 4
        var2 = var2 + (var1 * self._pressure_calibration[4] * 2)
        var2 = (var2 / 4) + (self._pressure_calibration[3] * 65536)
        var1 = (((((var1 / 4) * (var1 / 4)) / 8192) *
                (self._pressure_calibration[2] * 32) / 8) +
                ((self._pressure_calibration[1] * var1) / 2))
        var1 = var1 / 262144
        var1 = ((32768 + var1) * self._pressure_calibration[0]) / 32768
        calc_pres = 1048576 - self._adc_pres
        calc_pres = (calc_pres - (var2 / 4096)) * 3125
        calc_pres = (calc_pres / var1) * 2
        var1 = (self._pressure_calibration[8] * (((calc_pres / 8) * (calc_pres / 8)) / 8192)) / 4096
        var2 = ((calc_pres / 4) * self._pressure_calibration[7]) / 8192
        var3 = (((calc_pres / 256) ** 3) * self._pressure_calibration[9]) / 131072
        calc_pres += ((var1 + var2 + var3 + (self._pressure_calibration[6] * 128)) / 16)
        return calc_pres/100
    @property
    def humidity(self):
        """The relative humidity in RH %"""
        temp_scaled = ((self._t_fine * 5) + 128) / 256
        var1 = ((self._adc_hum - (self._humidity_calibration[0] * 16)) -
                ((temp_scaled * self._humidity_calibration[2]) / 200))
        var2 = (self._humidity_calibration[1] *
                (((temp_scaled * self._humidity_calibration[3]) / 100) +
                 (((temp_scaled * ((temp_scaled * self._humidity_calibration[4]) / 100)) /
                   64) / 100) + 16384)) / 1024
        var3 = var1 * var2
        var4 = self._humidity_calibration[5] * 128
        var4 = (var4 + ((temp_scaled * self._humidity_calibration[6]) / 100)) / 16
        var5 = ((var3 / 16384) * (var3 / 16384)) / 1024
        var6 = (var4 * var5) / 2
        calc_hum = (((var3 + var6) / 1024) * 1000) / 4096
        calc_hum /= 1000  # get back to RH
        if calc_hum > 100:
            calc_hum = 100
        if calc_hum < 0:
            calc_hum = 0
        return calc_hum
    @property
    def altitude(self):
        """The altitude based on current ``pressure`` vs the sea level pressure
           (``sea_level_pressure``) - which you must enter ahead of time)"""
        pressure = self.pressure # in Si units for hPascal
        return 44330 * (1.0 - math.pow(pressure / self.sea_level_pressure, 0.1903))
    @property
    def gas(self):
        """The gas resistance in ohms"""
        var1 = ((1340 + (5 * self._sw_err)) * (_LOOKUP_TABLE_1[self._gas_range])) / 65536
        var2 = ((self._adc_gas * 32768) - 16777216) + var1
        var3 = (_LOOKUP_TABLE_2[self._gas_range] * var1) / 512
        calc_gas_res = (var3 + (var2 / 2)) / var2
        return int(calc_gas_res)
    def _perform_reading(self):
        """Perform a single-shot reading from the sensor and fill internal data structure for
           calculations"""
        if time.ticks_diff(time.ticks_ms(), self._last_reading) < self._min_refresh_time:
            return
        # set filter
        self._write(_BME680_REG_CONFIG, [self._filter << 2])
        # turn on temp oversample & pressure oversample
        self._write(_BME680_REG_CTRL_MEAS,
                    [(self._temp_oversample << 5)|(self._pressure_oversample << 2)])
        # turn on humidity oversample
        self._write(_BME680_REG_CTRL_HUM, [self._humidity_oversample])
        # gas measurements enabled
        self._write(_BME680_REG_CTRL_GAS, [_BME680_RUNGAS])
        ctrl = self._read_byte(_BME680_REG_CTRL_MEAS)
        ctrl = (ctrl & 0xFC) | 0x01  # enable single shot!
        self._write(_BME680_REG_CTRL_MEAS, [ctrl])
        new_data = False
        while not new_data:
            data = self._read(_BME680_REG_STATUS, 15)
            new_data = data[0] & 0x80 != 0
            time.sleep(0.005)
        self._last_reading = time.ticks_ms()
        self._adc_pres = _read24(data[2:5]) / 16
        self._adc_temp = _read24(data[5:8]) / 16
        self._adc_hum = struct.unpack('>H', bytes(data[8:10]))[0]
        self._adc_gas = int(struct.unpack('>H', bytes(data[13:15]))[0] / 64)
        self._gas_range = data[14] & 0x0F
        var1 = (self._adc_temp / 8) - (self._temp_calibration[0] * 2)
        var2 = (var1 * self._temp_calibration[1]) / 2048
        var3 = ((var1 / 2) * (var1 / 2)) / 4096
        var3 = (var3 * self._temp_calibration[2] * 16) / 16384
        self._t_fine = int(var2 + var3)
    def _read_calibration(self):
        """Read & save the calibration coefficients"""
        coeff = self._read(_BME680_BME680_COEFF_ADDR1, 25)
        coeff += self._read(_BME680_BME680_COEFF_ADDR2, 16)
        coeff = list(struct.unpack('<hbBHhbBhhbbHhhBBBHbbbBbHhbb', bytes(coeff[1:39])))
        # print("\n\n",coeff)
        coeff = [float(i) for i in coeff]
        self._temp_calibration = [coeff[x] for x in [23, 0, 1]]
        self._pressure_calibration = [coeff[x] for x in [3, 4, 5, 7, 8, 10, 9, 12, 13, 14]]
        self._humidity_calibration = [coeff[x] for x in [17, 16, 18, 19, 20, 21, 22]]
        self._gas_calibration = [coeff[x] for x in [25, 24, 26]]
        # flip around H1 & H2
        self._humidity_calibration[1] *= 16
        self._humidity_calibration[1] += self._humidity_calibration[0] % 16
        self._humidity_calibration[0] /= 16
        self._heat_range = (self._read_byte(0x02) & 0x30) / 16
        self._heat_val = self._read_byte(0x00)
        self._sw_err = (self._read_byte(0x04) & 0xF0) / 16
    def _read_byte(self, register):
        """Read a byte register value and return it"""
        return self._read(register, 1)[0]
    def _read(self, register, length):
        raise NotImplementedError()
    def _write(self, register, values):
class BME680_I2C(Adafruit_BME680):
    """Driver for I2C connected BME680.
        :param int address: I2C device address
        :param bool debug: Print debug statements when True.
    def __init__(self, i2c, address=0x77, debug=False, *, refresh_rate=10):
        """Initialize the I2C device at the 'address' given"""
        self._i2c = i2c
        self._address = address
        self._debug = debug
        super().__init__(refresh_rate=refresh_rate)
        """Returns an array of 'length' bytes from the 'register'"""
        result = bytearray(length)
        self._i2c.readfrom_mem_into(self._address, register & 0xff, result)
        if self._debug:
            print("\t$%02X => %s" % (register, hex(result)))
        return result
        """Writes an array of 'length' bytes to the 'register'"""
        for value in values:
            self._i2c.writeto_mem(self._address, register, bytearray([value & 0xFF]))
            register += 1
        if self._debug:
            print("\t$%02X <= %s" % (values[0], hex(values[1:])))
IHOXOHI
Post by IHOXOHI » Mon Jun 29, 2020 5:14 pm
Thanks for your help!
I have tried to change the i2c adress by 0x78 althoug i2c.scan() return 0x77. And change "self._i2c.write(bytes([register & 0xFF]))" by self._i2c.write(bytes([register & 0x78])) : No success.
The solution of Roberthh is right.
It works fine!
Thanks a lot!!!
All the best!
Post by Roberthh » Mon Jun 29, 2020 6:54 pm
I created a repository here. I do not know why I did not have that already, since I adapted the driver quite a while ago.
https://github.com/robert-hh/BME680-Micropython
Post by pythoncoder » Tue Jun 30, 2020 4:15 am
A useful driver, but I think your README is truncated. Also your I2C line lacks constructor args (unless that's explained in the missing part of the README).
Post by Roberthh » Tue Jun 30, 2020 5:55 am
Thanks. There were some formatting issues. And I changed the test file for use with the micropython main line. The previous one was for use with the Pycom version, which has default pins for I2C.
As far as I recall, I did not upload these files earlier because I had not made a full readme yet - and then forgot about it. That will follow - forgetting too. Pointing to the Adafruit documentation might be confusing, because their examples are made for Circuitpython and it's tedious way of using I2C. The actual version of the Adafruit driver supports the SPI interface. So I may port that too.
IHOXOHI
Post by IHOXOHI » Tue Jun 30, 2020 9:18 am
Goood.
github's references have stranges behaviours on the net...with my system too?
For me, the humidity value is upper of 10 with reality. It's easy to correct it. Temperature and pressure are goods.
I have tried the bme.gas value... always the same result : 2938733 ...
Calcul of bme.gas is complex in the lib... I will try to find a correct way... If someone has an idea...
