bytes() makes a new copy of a bytes variable
kjw
Post by kjw » Thu Aug 06, 2020 7:16 pm
I noticed this in CircuitPython but just tested a micro:bit and it does the same thing. bytes() makes a new copy of an object even if it's bytes() already.
MicroPython v1.9.2-34-gd64154c73 on 2017-09-01; micro:bit v1.0.1 with nRF51822
>>> a = b"Original"
>>> b = a
>>> c = bytes(a)
>>> type(a)
<class 'bytes'>
>>> a is b
True
>>> a is c
False
>>> id(a)
536871968
>>> id(b)
536871968
>>> id(c)
536871840
I tried a few versions of CPython and it just returns the original. Is there a reason for a copy being made here of this (immutable) type?
Re: bytes() makes a new copy of a bytes variable
Post by pythoncoder » Fri Aug 07, 2020 7:34 am
This does seem like a bug. The Unix build has the same behaviour.
Strings behave correctly. On the Unix build:
>>> s = 'rats'
>>> t = str(s)
>>> t is s
True
which is as per CPython.
Iyassou
Post by Iyassou » Fri Sep 18, 2020 11:40 am
I've submitted a pull request for this :)
