one SPI ist the for the TFT Port and a other for the SD Card.
Only Difference ist an other Chipselect Output.Pin- mosi/miso usw use the same Pins - technical no problem
The Driver for the TFT toggels the Chipselect - so no problem -
but toggels the SD Card Class the CS Pin ?
CS High > low > read/write > CS High - that is what i need
Or must i write an toggel the CS Pin def for read/write to SD
