epaper's waveshare lib
IHOXOHI
Post by IHOXOHI » Sat Oct 24, 2020 8:57 am
I tested differents formats of epaper by waveshare(2in7, 2in9,4in2 and 7in5). I use mcauser's lib. It's important to check version because waveshare has produce a lots of "new" version like v2 for example.
Check if there is one line DIN or 2 lines MOSI and MISO is very important too, to choice a good driver.
For me, 2in9 (DIN) and 4in2 (MOSI and MISO) formats works perfectly with mcauser's libs.
With the font_to_py.py and writer module by pythoncoder, the result is beautiful, but in this case, a bug appears after nearly 500 cycles of 60 sec with a pyb-d.
The 2in7 doesn't woks. The return is about a "LUT_BW" which is not indicated. I have changed this constant with others LUT_constantes, without success (no return, nothing happen, blocked prompt)... It seems that this epaper need an initiate like the 2.9 with a MASTER SPI state, but a framebuffer use like the 4.2 in micropython language without SPI MASTER state...
The 7in5 can works if I change in the lib the division of display_frame def (8 by 4) with a pyb-d,
def display_frame(self, frame_buffer):
        self._command(DATA_START_TRANSMISSION_1)
        for i in range(0, self.width * self.height // 4):
but then it concern only half of the display. Maybe it could be a problem of computation's capacity (7in5 is very big). The return without change is about "bytearray index out of"...
I tried 2in13d and v2, 1in54v2 format without success. for moment...
IHOXOHI
Re: epaper's waveshare lib
Post by IHOXOHI » Tue Oct 27, 2020 4:32 pm
Yep,
I wrote something "quickly" just to troubleshoot displaying larger print during long time.
This is la lilttle bit long and just for numbers, m, v, and c letters.
I don't succeed to put alls def of each number or letter in other file that we could import... If someone has an advise for doing that... maybe I can write something for alls letters and others differents sizes...
the code of alls def of numbers...:
##each number has 9 pixels on xplan and 13 pixels on yplan
def space(a,b):
    pass
def lettre_m(a,b):
    fb.vline(1+a,1+b, 13, black)
    fb.vline(2+a,1+b, 13, black)
    fb.vline(3+a,2+b, 2, black)
    fb.vline(4+a,3+b, 2, black)
    fb.vline(5+a,4+b, 2, black)
    fb.vline(6+a,3+b, 2, black)
    fb.vline(7+a,2+b, 2, black)
    fb.vline(8+a,1+b, 13, black)
    fb.vline(9+a,1+b, 13, black)
def lettre_v(a,b):
    fb.vline(1+a,1+b, 4, black)
    fb.vline(2+a,1+b, 7, black)
    fb.vline(3+a,4+b, 7, black)
    fb.vline(4+a,7+b, 7, black)
    fb.vline(5+a,10+b, 4, black)
    fb.vline(6+a,7+b, 7, black)
    fb.vline(7+a,4+b, 7, black)
    fb.vline(8+a,1+b, 7, black)
    fb.vline(9+a,1+b, 4, black)
def lettre_c(a,b):
    fb.hline(5+a,1+b, 5, black)
    fb.hline(4+a,2+b, 6, black)
    fb.hline(3+a,3+b, 3, black)
    fb.hline(2+a,4+b, 3, black)
    fb.hline(2+a,5+b, 2, black)
    fb.vline(1+a,6+b, 3, black)
    fb.vline(2+a,6+b, 5, black)
    fb.vline(3+a,9+b, 3, black)
    fb.vline(4+a,10+b, 3, black)
    fb.vline(5+a,11+b, 3, black)
    fb.hline(6+a,12+b, 4, black)
    fb.hline(6+a,13+b, 4, black)
def pourcent(a,b):
    fb.vline(1+a,10+b, 3, black)
    fb.vline(2+a,9+b, 3, black)
    fb.vline(3+a,8+b, 3, black)
    fb.vline(4+a,7+b, 3, black)
    fb.vline(5+a,6+b, 3, black)
    fb.vline(6+a,5+b, 3, black)
    fb.vline(7+a,4+b, 3, black)
    fb.vline(8+a,3+b, 3, black)
    fb.vline(9+a,2+b, 3, black)
    fb.vline(3+a,3+b, 2, black)
    fb.vline(5+a,3+b, 2, black)
    fb.vline(2+a,2+b, 3, black)
    fb.vline(3+a,1+b, 5, black)
    fb.vline(4+a,1+b, 5, black)
    fb.vline(5+a,2+b, 3, black)
    fb.vline(6+a,9+b, 3, black)
    fb.vline(7+a,8+b, 5, black)
    fb.vline(8+a,8+b, 5, black)
    fb.vline(9+a,9+b, 3, black)
def slash(a,b):
    fb.vline(1+a,10+b, 2, black)
    fb.vline(2+a,10+b, 2, black)
    fb.vline(2+a,8+b, 2, black)
    fb.vline(3+a,8+b, 2, black)
    fb.vline(3+a,6+b, 2, black)
    fb.vline(4+a,6+b, 2, black)
    fb.vline(4+a,4+b, 2, black)
    fb.vline(5+a,2+b, 2, black)
    fb.vline(6+a,2+b, 2, black)
def point2(a,b):
    fb.hline(2+a,11+b, 2, black)
    fb.hline(2+a,10+b, 2, black)
    fb.hline(2+a,7+b, 2, black)
    fb.hline(2+a,6+b, 2, black)
def point(a,b):
    fb.hline(2+a,12+b, 2, black)
    fb.hline(2+a,13+b, 2, black)
def number_0(a,b):
    fb.vline(2+a,3+b, 9, black)
    fb.vline(3+a,2+b, 4, black)
    fb.vline(3+a,9+b, 4, black)
    fb.vline(4+a,1+b, 3, black)
    fb.vline(4+a,11+b, 3, black)
    fb.vline(5+a,1+b, 2, black)
    fb.vline(5+a,12+b, 2, black)
    fb.vline(6+a,1+b, 3, black)
    fb.vline(6+a,11+b, 3, black)
    fb.vline(7+a,2+b, 4, black)
    fb.vline(7+a,9+b, 4, black)
    fb.vline(8+a,3+b, 9, black)
    fb.vline(9+a,6+b, 3, black)
def number_1(a,b):
    fb.vline(6+a,1+b, 13, black)
    fb.vline(7+a,1+b, 13, black)
    fb.vline(3+a,4+b, 2, black)
    fb.pixel(2,5)
def number_2(a,b):
    fb.hline(4+a,1+b, 3, black)
    fb.hline(3+a,2+b, 5, black)
    fb.hline(2+a,3+b, 2, black)
    fb.hline(7+a,3+b, 2, black)
    fb.hline(1+a,4+b, 2, black)
    fb.hline(8+a,4+b, 2, black)
    fb.hline(1+a,5+b, 2, black)
    fb.hline(8+a,5+b, 2, black)
    fb.hline(7+a,6+b, 2, black)
    fb.hline(6+a,7+b, 2, black)
    fb.hline(5+a,8+b, 2, black)
    fb.hline(4+a,9+b, 2, black)
    fb.hline(3+a,10+b, 2, black)
    fb.hline(1+a,12+b, 9, black)
    fb.hline(1+a,13+b, 9, black)
def number_3(a,b):
    fb.hline(1+a,1+b, 7, black)
    fb.hline(1+a,2+b, 7, black)
    fb.hline(4+a,6+b, 4, black)
    fb.hline(3+a,7+b, 5, black)
    fb.hline(4+a,8+b, 4, black)
    fb.hline(1+a,12+b, 7, black)
    fb.hline(1+a,13+b, 7, black)
def number_4(a,b):
    fb.vline(2+a,8+b, 4, black)
    fb.vline(3+a,7+b, 5, black)
    fb.hline(4+a,10+b, 6, black)
    fb.hline(4+a,11+b, 6, black)
    fb.vline(7+a,8+b, 6, black)
    fb.vline(8+a,8+b, 6, black)
    fb.vline(5+a,5+b, 2, black)
    fb.vline(6+a,4+b, 2, black)
    fb.vline(7+a,3+b, 2, black)
    fb.vline(8+a,2+b, 2, black)
    fb.vline(9+a,1+b, 2, black)
def number_5(a,b):
    fb.hline(1+a,1+b, 9, black)
    fb.hline(1+a,2+b, 9, black)
    fb.vline(1+a,3+b, 5, black)
    fb.vline(2+a,3+b, 5, black)
    fb.hline(3+a,6+b, 4, black)
    fb.hline(3+a,7+b, 6, black)
    fb.hline(6+a,8+b, 4, black)
    fb.hline(8+a,9+b, 2, black)
    fb.hline(8+a,10+b, 2, black)
    fb.hline(6+a,11+b, 4, black)
    fb.hline(1+a,12+b, 8, black)
    fb.hline(1+a,13+b, 6, black)
def number_6(a,b):
    fb.hline(4+a,1+b, 6, black)
    fb.hline(3+a,2+b, 7, black)
    fb.vline(1+a,5+b, 6, black)
    fb.vline(3+a,7+b, 6, black)
    fb.hline(4+a,6+b, 3, black)
    fb.hline(4+a,7+b, 5, black)
    fb.hline(5+a,13+b, 2, black)
    fb.hline(5+a,12+b, 3, black)
    fb.hline(6+a,11+b, 3, black)
    fb.hline(7+a,8+b, 3, black)
def number_7(a,b):
    fb.hline(1+a,1+b, 6, black)
    fb.hline(1+a,2+b, 6, black)
    fb.vline(5+a,3+b, 11, black)
    fb.vline(6+a,3+b, 11, black)
    fb.hline(3+a,6+b, 6, black)
def number_8(a,b):
    fb.hline(7+a,5+b, 2, black)
    fb.hline(3+a,6+b, 5, black)
    fb.hline(4+a,7+b, 3, black)
    fb.hline(3+a,8+b, 5, black)
    fb.hline(2+a,9+b, 2, black)
    fb.hline(7+a,9+b, 2, black)
    fb.hline(1+a,10+b, 2, black)
    fb.hline(7+a,11+b, 2, black)
    fb.hline(3+a,12+b, 5, black)
    fb.hline(4+a,13+b, 3, black)
def number_9(a,b):
    fb.hline(2+a,13+b, 5, black)
    fb.hline(2+a,12+b, 6, black)
    fb.hline(7+a,11+b, 3, black)
    fb.vline(9+a,4+b, 8, black)
    fb.hline(2+a,6+b, 6, black)
    fb.hline(1+a,5+b, 3, black)
    fb.hline(6+a,5+b, 2, black)
    fb.pixel(7+a,4+b)
    fb.hline(1+a,3+b, 3, black)
    fb.hline(2+a,2+b, 6, black)
The code to use it in a main file:
def conversion(number, a, b):
    number = str(number)
    a = str(a)
    b = str(b)
    liste_noms_symbols = ["number_0", "number_1", "number_2", "number_3", "number_4", "number_5", "number_6", "number_7", "number_8", "number_9", "point", "point2", "slash", "pourcent", "lettre_m", "lettre_c", "lettre_v", "space"]
    liste_symbols = ["0", "1", "2", "3", "4", "5", "6", "7", "8", "9", ".", ":", "/", "%", "M", "C", "V", " "]
    for i in liste_symbols:
        if i == number:
            phrasi = liste_noms_symbols[liste_symbols.index(i)] + "(" + a + "," + b + ")"
    convert = eval(phrasi)
    return convert
def affichage(numbers,a,b=0):
    numbers = str(numbers)
    for i in numbers:
        i = str(i)
        if i == ":" or i == ".":
            conversion(i,a,b)
        if i == "/":
            conversion(i,a,b)
            a += 8
            conversion(i,a,b)
            a += 12
while 1:
    fb.fill(white)
    affichage("{}/{}".format(jour,mois),62,10)
    affichage("{}:{}".format(heure,minu),240,10)
    affichage("{}C".format(temp),150,70)
    affichage("{}%".format(hum),150,110)
    affichage(luxi,150,150)
    affichage("C02:{}".format(co2),150,190)
    affichage("V0C:{}".format(voc),150,230)
    affichage(count,150,260)
    e.display_frame(buf)
    time.sleep(60)
For sure, it will be better to change directly something in the buffer behaviour to increase correctly the size of displaying symbols.
But, how do that?
Thanks.
IHOXOHI
Post by IHOXOHI » Thu Oct 29, 2020 10:00 pm
Yup,
The code (859 lignes) for alls letters, numbers with . : / % + - = _ ! ? symbols:
def space(a,b):
    pass
def lettre_A(a,b):
    fb.vline(4+a,1+b, 6, black)
    fb.vline(5+a,1+b, 3, black)
    fb.vline(6+a,1+b, 6, black)
    fb.vline(2+a,7+b, 7, black)
    fb.vline(1+a,11+b, 3, black)
    fb.vline(8+a,7+b, 7, black)
    fb.vline(9+a,11+b, 3, black)
    fb.hline(4+a,9+b, 3, black)
    fb.hline(4+a,10+b, 3, black)
def lettre_B(a,b):
    fb.hline(3+a,1+b, 3, black)
    fb.hline(3+a,2+b, 6, black)
    fb.hline(6+a,3+b, 4, black)
    fb.hline(6+a,5+b, 4, black)
    fb.hline(3+a,7+b, 4, black)
    fb.hline(5+a,8+b, 4, black)
    fb.hline(6+a,9+b, 4, black)
    fb.hline(3+a,12+b, 6, black)
    fb.hline(3+a,13+b, 4, black)
def lettre_C(a,b):
def lettre_D(a,b):
    fb.hline(3+a,1+b, 2, black)
    fb.hline(3+a,2+b, 4, black)
    fb.hline(3+a,3+b, 5, black)
    fb.hline(6+a,4+b, 2, black)
    fb.hline(7+a,5+b, 3, black)
    fb.vline(8+a,6+b, 5, black)
    fb.vline(9+a,6+b, 4, black)
    fb.vline(7+a,9+b, 3, black)
    fb.pixel(6+a,10+b, black)
    fb.hline(3+a,11+b, 4, black)
    fb.hline(3+a,12+b, 4, black)
    fb.hline(3+a,13+b, 2, black)
def lettre_E(a,b):
    fb.hline(3+a,1+b, 7, black)
    fb.hline(3+a,12+b, 7, black)
    fb.hline(3+a,13+b, 7, black)
def lettre_F(a,b):
def lettre_G(a,b):
    fb.hline(4+a,1+b, 5, black)
    fb.vline(3+a,10+b, 3, black)
    fb.hline(4+a,12+b, 4, black)
def lettre_H(a,b):
def lettre_I(a,b):
    fb.vline(5+a,3+b, 10, black)
    fb.vline(6+a,3+b, 10, black)
    fb.vline(4+a,3+b, 10, black)
    fb.hline(2+a,1+b, 7, black)
    fb.hline(2+a,2+b, 7, black)
    fb.hline(2+a,13+b, 7, black)
    fb.hline(2+a,12+b, 7, black)
def lettre_J(a,b):
    fb.vline(6+a,3+b, 9, black)
    fb.vline(7+a,3+b, 8, black)
    fb.vline(5+a,10+b, 3, black)
    fb.vline(3+a,11+b, 3, black)
    fb.vline(2+a,9+b, 4, black)
    fb.vline(1+a,9+b, 3, black)
def lettre_K(a,b):
    fb.vline(3+a,6+b, 3, black)
    fb.vline(4+a,5+b, 5, black)
    fb.vline(5+a,4+b, 3, black)
    fb.vline(6+a,3+b, 3, black)
    fb.vline(7+a,2+b, 3, black)
    fb.vline(8+a,1+b, 3, black)
    fb.vline(5+a,8+b, 3, black)
    fb.vline(7+a,10+b, 3, black)
    fb.vline(8+a,11+b, 3, black)
    fb.vline(9+a,12+b, 2, black)
def lettre_L(a,b):
    fb.hline(3+a,13+b, 6, black)
def lettre_M(a,b):
    fb.vline(4+a,3+b, 3, black)
def lettre_N(a,b):
    fb.vline(4+a,2+b, 5, black)
    fb.vline(5+a,5+b, 5, black)
    fb.vline(6+a,7+b, 5, black)
    fb.vline(7+a,9+b, 5, black)
def lettre_P(a,b):
    fb.hline(3+a,7+b, 3, black)
def lettre_Q(a,b):
    fb.vline(5+a,9+b, 2, black)
    fb.vline(6+a,9+b, 2, black)
    fb.vline(8+a,12+b, 2, black)
def lettre_R(a,b):
    fb.hline(6+a,9+b, 2, black)
    fb.hline(7+a,10+b, 2, black)
    fb.hline(8+a,11+b, 2, black)
    fb.hline(8+a,12+b, 2, black)
    fb.hline(8+a,13+b, 2, black)
def lettre_S(a,b):
    fb.hline(3+a,6+b, 3, black)
    fb.hline(5+a,8+b, 3, black)
def lettre_T(a,b):
    fb.vline(4+a,3+b, 11, black)
def lettre_U(a,b):
    fb.vline(1+a,1+b, 10, black)
    fb.vline(2+a,1+b, 11, black)
    fb.vline(8+a,1+b, 11, black)
    fb.vline(9+a,1+b, 10, black)
def lettre_V(a,b):
def lettre_W(a,b):
    fb.vline(1+a,1+b, 5, black)
    fb.vline(2+a,1+b, 9, black)
    fb.vline(3+a,5+b, 9, black)
    fb.vline(4+a,9+b, 5, black)
    fb.vline(6+a,9+b, 5, black)
    fb.vline(7+a,5+b, 9, black)
    fb.vline(8+a,1+b, 9, black)
    fb.vline(9+a,1+b, 5, black)
def lettre_X(a,b):
    fb.vline(1+a,1+b, 2, black)
    fb.vline(2+a,1+b, 4, black)
    fb.vline(3+a,2+b, 5, black)
    fb.vline(4+a,4+b, 7, black)
    fb.vline(6+a,4+b, 7, black)
    fb.vline(7+a,2+b, 5, black)
    fb.vline(8+a,1+b, 4, black)
    fb.vline(3+a,8+b, 5, black)
    fb.vline(2+a,10+b, 4, black)
    fb.vline(1+a,12+b, 2, black)
    fb.vline(8+a,10+b, 4, black)
def lettre_Y(a,b):
    fb.vline(6+a,4+b, 4, black)
def lettre_Z(a,b):
    fb.hline(7+a,3+b, 3, black)
    fb.hline(6+a,4+b, 3, black)
    fb.vline(7+a,5+b, 2, black)
    fb.pixel(5+a,6+b, black)
    fb.hline(3+a,8+b, 3, black)
    fb.vline(4+a,9+b, 2, black)
    fb.pixel(1+a,11+b, black)
def pourcent(a,b):
def slash(a,b):
def point2(a,b):
    fb.hline(4+a,10+b, 2, black)
    fb.hline(4+a,7+b, 2, black)
    fb.hline(4+a,6+b, 2, black)
def point(a,b):
    fb.hline(4+a,12+b, 2, black)
    fb.hline(4+a,13+b, 2, black)
def plus(a,b):
    fb.hline(1+a,6+b, 9, black)
    fb.hline(1+a,7+b, 9, black)
    fb.hline(1+a,8+b, 9, black)
    fb.vline(4+a,3+b, 9, black)
    fb.vline(5+a,3+b, 9, black)
def moins(a,b):
    fb.hline(2+a,6+b, 7, black)
    fb.hline(2+a,7+b, 7, black)
    fb.hline(2+a,8+b, 7, black)
def egal(a,b):
    fb.hline(2+a,5+b, 7, black)
    fb.hline(2+a,9+b, 7, black)
def underscore(a,b):
def interrogation(a,b):
    fb.vline(3+a,1+b, 4, black)
    fb.vline(4+a,1+b, 2, black)
    fb.vline(6+a,2+b, 5, black)
    fb.vline(7+a,3+b, 3, black)
    fb.vline(5+a,6+b, 5, black)
    fb.vline(4+a,7+b, 4, black)
    fb.vline(4+a,12+b, 2, black)
def exclamation(a,b):
    fb.vline(4+a,1+b, 10, black)
    fb.vline(5+a,1+b, 10, black)
def number_0(a,b):
def number_1(a,b):
    fb.pixel(2+a,5+b, black)
def number_2(a,b):
def number_3(a,b):
    fb.hline(1+a,2+b, 8, black)
    fb.pixel(7+a,3+b, black)
    fb.vline(8+a,2+b, 10, black)
    fb.vline(9+a,3+b, 9, black)
    fb.hline(4+a,7+b, 4, black)
    fb.pixel(7+a,11+b, black)
def number_4(a,b):
    fb.vline(6+a,2+b, 3, black)
def number_5(a,b):
def number_6(a,b):
def number_7(a,b):
    fb.vline(5+a,8+b, 6, black)
    fb.vline(6+a,8+b, 6, black)
    fb.hline(4+a,6+b, 5, black)
def number_8(a,b):
def number_9(a,b):
    fb.pixel(7+a,4+b)
def lettre_a(a,b):
    fb.hline(4+a,5+b, 3, black)
    fb.vline(3+a,7+b, 3, black)
    fb.vline(2+a,7+b, 3, black)
    fb.vline(7+a,7+b, 3, black)
    fb.vline(8+a,6+b, 6, black)
    fb.vline(4+a,9+b, 3, black)
    fb.vline(5+a,10+b, 2, black)
def lettre_b(a,b):
    fb.vline(3+a,1+b, 11, black)
    fb.hline(4+a,5+b, 2, black)
    fb.hline(6+a,7+b, 3, black)
    fb.vline(7+a,8+b, 3, black)
    fb.vline(8+a,8+b, 2, black)
    fb.hline(4+a,11+b, 2, black)
def lettre_c(a,b):
    fb.vline(2+a,5+b, 5, black)
    fb.hline(5+a,3+b, 2, black)
    fb.hline(5+a,4+b, 4, black)
    fb.hline(6+a,5+b, 3, black)
    fb.hline(5+a,11+b, 2, black)
    fb.hline(5+a,10+b, 4, black)
    fb.hline(6+a,9+b, 3, black)
    fb.hline(7+a,8+b, 2, black)
def lettre_d(a,b):
    fb.vline(7+a,1+b, 11, black)
    fb.hline(5+a,5+b, 3, black)
    fb.hline(2+a,7+b, 3, black)
    fb.hline(2+a,8+b, 2, black)
    fb.hline(2+a,9+b, 3, black)
    fb.hline(3+a,10+b, 4, black)
    fb.hline(4+a,11+b, 3, black)
def lettre_e(a,b):
    fb.vline(2+a,6+b, 4, black)
    fb.vline(3+a,5+b, 6, black)
    fb.hline(4+a,4+b, 4, black)
    fb.hline(4+a,5+b, 5, black)
    fb.hline(4+a,8+b, 5, black)
    fb.hline(5+a,11+b, 4, black)
def lettre_f(a,b):
    fb.vline(3+a,2+b, 10, black)
    fb.hline(4+a,1+b, 4, black)
    fb.hline(4+a,2+b, 4, black)
def lettre_g(a,b):
    fb.vline(3+a,6+b, 5, black)
    fb.vline(7+a,6+b, 7, black)
    fb.vline(8+a,7+b, 5, black)
    fb.hline(3+a,12+b, 3, black)
    fb.hline(3+a,13+b, 3, black)
def lettre_h(a,b):
    fb.vline(6+a,6+b, 4, black)
    fb.vline(7+a,7+b, 5, black)
    fb.vline(8+a,9+b, 3, black)
def lettre_i(a,b):
    fb.vline(4+a,2+b, 2, black)
    fb.vline(3+a,5+b, 7, black)
    fb.vline(4+a,5+b, 7, black)
def lettre_j(a,b):
    fb.vline(6+a,1+b, 2, black)
    fb.vline(7+a,1+b, 2, black)
    fb.vline(6+a,5+b, 10, black)
    fb.vline(4+a,8+b, 2, black)
def lettre_k(a,b):
    fb.hline(5+a,5+b, 2, black)
    fb.hline(4+a,8+b, 2, black)
def lettre_l(a,b):
def lettre_m(a,b):
    fb.hline(1+a,6+b, 8, black)
    fb.hline(2+a,5+b, 6, black)
    fb.vline(1+a,7+b, 5, black)
    fb.vline(2+a,7+b, 5, black)
    fb.vline(4+a,7+b, 5, black)
    fb.vline(5+a,7+b, 5, black)
def lettre_n(a,b):
    fb.vline(2+a,5+b, 7, black)
    fb.vline(6+a,6+b, 6, black)
    fb.vline(7+a,6+b, 6, black)
def lettre_o(a,b):
    fb.hline(4+a,4+b, 2, black)
    fb.hline(3+a,5+b, 4, black)
    fb.vline(4+a,10+b, 2, black)
    fb.vline(6+a,6+b, 5, black)
    fb.vline(7+a,6+b, 4, black)
def lettre_p(a,b):
    fb.vline(2+a,4+b, 10, black)
    fb.vline(3+a,4+b, 10, black)
    fb.hline(4+a,4+b, 3, black)
    fb.hline(4+a,5+b, 4, black)
    fb.hline(6+a,6+b, 2, black)
    fb.hline(4+a,8+b, 3, black)
def lettre_q(a,b):
    fb.vline(6+a,4+b, 10, black)
    fb.vline(7+a,4+b, 10, black)
    fb.hline(3+a,4+b, 3, black)
    fb.hline(2+a,5+b, 4, black)
    fb.hline(2+a,7+b, 4, black)
def lettre_r(a,b):
    fb.vline(2+a,4+b, 8, black)
    fb.vline(3+a,4+b, 8, black)
    fb.vline(4+a,5+b, 3, black)
    fb.vline(5+a,5+b, 3, black)
def lettre_s(a,b):
    fb.hline(2+a,4+b, 7, black)
    fb.hline(2+a,6+b, 5, black)
    fb.hline(2+a,10+b, 7, black)
    fb.hline(3+a,11+b, 5, black)
def lettre_t(a,b):
    fb.vline(4+a,2+b, 9, black)
    fb.vline(5+a,2+b, 10, black)
    fb.vline(7+a,4+b, 2, black)
    fb.vline(6+a,10+b, 2, black)
def lettre_u(a,b):
    fb.vline(2+a,4+b, 6, black)
    fb.vline(8+a,4+b, 6, black)
def lettre_v(a,b):
    fb.vline(2+a,4+b, 3, black)
    fb.vline(3+a,4+b, 6, black)
    fb.vline(6+a,7+b, 4, black)
    fb.vline(7+a,4+b, 6, black)
    fb.vline(8+a,4+b, 3, black)
def lettre_w(a,b):
    fb.vline(5+a,8+b, 2, black)
def lettre_x(a,b):
    fb.vline(2+a,3+b, 3, black)
    fb.vline(3+a,3+b, 4, black)
    fb.vline(6+a,5+b, 5, black)
    fb.vline(7+a,3+b, 4, black)
    fb.vline(3+a,8+b, 4, black)
    fb.vline(7+a,8+b, 4, black)
def lettre_y(a,b):
    fb.vline(8+a,5+b, 7, black)
    fb.vline(7+a,5+b, 8, black)
    fb.vline(3+a,5+b, 4, black)
    fb.vline(2+a,5+b, 3, black)
    fb.hline(4+a,12+b, 3, black)
def lettre_z(a,b):
    fb.hline(5+a,7+b, 2, black)
    fb.hline(3+a,9+b, 2, black)
    fb.hline(2+a,11+b, 7, black)
    a = str(a)
    b = str(b)
    liste_noms_symbols = ["space", "lettre_A", "lettre_B", "lettre_C", "lettre_D", "lettre_E", "lettre_F", "lettre_G", "lettre_H", "lettre_I", "lettre_J", "lettre_K", "lettre_L", "lettre_M", "lettre_N", "number_0", "lettre_P", "lettre_Q", "lettre_R", "lettre_S", "lettre_T", "lettre_U", "lettre_V", "lettre_W", "lettre_X", "lettre_Y", "lettre_Z", "point", "point2", "slash", "pourcent", "plus", "moins", "egal", "underscore", "interrogation", "exclamation", "number_0", "number_1", "number_2", "number_3", "number_4", "number_5", "number_6", "number_7", "number_8", "number_9", "lettre_a", "lettre_b", "lettre_c", "lettre_d", "lettre_e", "lettre_f", "lettre_g", "lettre_h", "lettre_i", "lettre_j", "lettre_k", "lettre_l", "lettre_m", "lettre_n", "lettre_o", "lettre_p", "lettre_q", "lettre_r", "lettre_s", "lettre_t", "lettre_u", "lettre_v", "lettre_w", "lettre_x", "lettre_y", "lettre_z"]
    liste_symbols = [" ", "A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "L", "M", "N", "O", "P", "Q", "R", "S", "T", "U", "V", "W", "X", "Y", "Z", ".", ":", "/", "%", "+", "-", "=", "_", "?", "!", "0", "1", "2", "3", "4", "5", "6", "7", "8", "9", "a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m", "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z" ]
        if i == number:
    return convert
    memo_b = b
    #sautx_4 = []
    sautx_6 = [" ", "!", "f", "i", "l", "r"]
    sautx_8 = ["/", ".", "n", "o"]
    sautx_10 = [":", "?", "a", "b", "c", "d", "e", "g", "h", "j", "k", "m", "p", "q", "s", "t", "u", "v", "w", "x", "y", "z", "L"]
    sautx_11 = ["%", "=", "_", "A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "M", "N", "O", "P", "Q", "R", "S", "T", "U", "V", "W", "X", "Y", "Z", "0", "1", "2", "3", "4", "5", "6", "7", "8", "9", "+", "-"]
    sauty_2 = ["a", "b", "c", "d", "e", "f", "h", "i", "k", "l", "m", "n", "o", "r", "s", "t", "u", "v", "w", "x", "z"]
    sauty_3 = ["g", "j", "y"]
    sauty_4 = ["p", "q"]
    for i in numbers:
        i = str(i)
        if i in sauty_2:
            b += 2
        if i in sauty_3:
            b += 3
        if i in sauty_4:
            b += 4
        #if i in sautx_4:
         #   conversion(i,a,b)
          #  a += 4
        if i in sautx_6:
            conversion(i,a,b)
            a += 6
        if i in sautx_8:
            conversion(i,a,b)
            a += 8
        if i in sautx_10:
            conversion(i,a,b)
            a += 10
        if i in sautx_11:
            conversion(i,a,b)
            a += 11
        b = memo_b
I haven't succed to put all this code in other file that I could import. It works fine, but It's too heavy for a main...
If someone could advise me on this point... (the difficulties comes from the eval function)
Thanks.
IHOXOHI
Post by IHOXOHI » Mon Nov 02, 2020 10:22 am
Youpi,
I have got it...
It was easy!!!?
I don't understand why anybody teach me how use a framebuff by the lib folder???
The first lines, and the last lines of my font.py file, in my lib folder, that I could import in the main:
import framebuf
def __init__(self, a, b, fb, i):
    self.conversion = conversion(a,b,fb,i)
    self.buf = bytearray(400 * 300 // 8)
    self.fb = framebuf.FrameBuffer(buf, 400, 300, framebuf.MONO_HLSB)
    self.space = space(a,b,fb)
    self.lettre_A = lettre_A(a,b,fb)
    self.lettre_B = lettre_B(a,b,fb)
    self.lettre_C = lettre_C(a,b,fb)
    self.lettre_D = lettre_D(a,b,fb)
    self.lettre_E = lettre_E(a,b,fb)
    def conversion(a, b,fb,number):
    a = str(a)
    b = str(b)
    liste_noms_symbols = ["space", "lettre_A", "lettre_B", "lettre_C", ..., "lettre_w", "lettre_x", "lettre_y", "lettre_z"]
    liste_symbols = [" ", "A", "B", "C", "D", "E", ..., "r", "s", "t", "u", "v", "w", "x", "y", "z" ]
        if i == number:
            phrasi = liste_noms_symbols[liste_symbols.index(i)] + "(" + a + "," + b + "," + "fb" +")"
    return convert
How I call it in my main:
    memo_b = b
    #sautx_4 = []
    for i in numbers:
        i = str(i)
        if i in sauty_2:
            b += 2
        if i in sauty_3:
            b += 3
        if i in sauty_4:
            b += 4
        #if i in sautx_4:
         #   conversion(i,a,b)
          #  a += 4
        if i in sautx_6:
            ft.conversion(a,b,fb,i)
            a += 6
        if i in sautx_8:
            a += 8
        if i in sautx_10:
            a += 10
        if i in sautx_11:
            a += 11
        b = memo_b
        while 1:
            fb.fill(white)
            affichage("abcdefghijklmnopqrstuvwxyz",62,230)
            affichage("1234567890 ./:%+-=?_!",62,250)
            affichage("ABCDEFGHIJKLMNOPQRSTUVWXYZ",30,275)
            time.sleep(60)
For moment, no problem, but I haven't tested during 500 cycles of 60 sec yet... Once it will be, I will put the font.py file in "a place" on the www and post there the adress...
Works only with pyb-d which has enough memory capacity.
https://www.cosmocratie.fr/gallery.html
For others boards with less memory, you can reduce the number of symbols in the lib. I will add a shorted version...
Thanks for yours supports.
