1.13 - import libs is slower than 1.12 ?
prem111
Post by prem111 » Wed Oct 28, 2020 6:59 pm
Hi. I noticed that the library imports slower in version 1.13. What is it caused by? I am using the unstable version.
stijn
Re: 1.13 - import libs is slower than 1.12 ?
Post by stijn » Wed Oct 28, 2020 7:11 pm
Which libraries, and how did you measure this exactly?
Post by jimmo » Wed Oct 28, 2020 11:51 pm
And which board/port are you using?
The ESP32 and ESP8266 ports are very sensitive to code location changes due to caching effects and architectural issues. I see quite dramatic speed differences from just re-arranging code that is otherwise functionally identical.
prem111
Post by prem111 » Thu Oct 29, 2020 8:07 am
Board is esp32. But it is like that with every boot. The difference can be seen when importing e.g. uasyncio.
Post by jimmo » Thu Oct 29, 2020 10:51 am
How did you measure it? How much difference is there?
Note that in 1.13 vs 1.12 would be a different version of uasyncio too (v3 vs v2).
