Max current out of 3V3?
mathieu
Post by mathieu » Thu Nov 19, 2020 10:26 pm
I feel like this question must be answered somewhere, but I've been looking for some time now with no success: what is the max current that can be safely supplied by each of the 3V3 pins of the pyboard 1.1?
Re: Max current out of 3V3?
Post by jimmo » Thu Nov 19, 2020 10:37 pm
Are you asking how much current can each of the GPIO pins source, or the 3.3 power pins?
The GPIO pins can source (and sink) 25mA each and a combined total of ~240mA (See https://www.st.com/resource/en/datasheet/dm00037051.pdf)
On the v1.1, the 3.3V power pins all share the same regulator (which is also used by everything on the board) which can supply 250mA. (See https://store.micropython.org/product/PYBv1.1)
Online
Post by pythoncoder » Fri Nov 20, 2020 8:17 am
This statement needs some qualification.
The spec says "capable of supplying up to 250mA, input voltage range 3.6V to 16V ". The 3V3 regulator is a linear device sourced from V+. If V+ is 5V then a current of 250mA looks feasible, with the regulator dissipating (5 - 3.3)*0.25 = 0.425W. At the other extreme, with Vin == 16V, available current will be much less.
Calculating a worst-case figure is a little involved as it involves thermal issues but you can be sure the regulator would go into thermal protection under those conditions.
Post by jimmo » Fri Nov 20, 2020 12:33 pm
This is a very important qualification. Thanks Peter!
