docs as pdf are missing
Hello I'm new with Micropython,
since I want to read about, I found out the pdf is missing. http://docs.micropython.org/en/v1.13/mi ... n-docs.pdf and http://docs.micropython.org/en/latest/m ... n-docs.pdf are empty.
Re: docs as pdf are missing
I don't think these are routinely built. You can build a local copy of the docs, in HTML or PDF form, by following these instructions.
Thanks for your answer, but I'm a complete linux beginner and have no clue about latex
After solving some problems, I get this
Line 128 in Makefile: $(SPHINXBUILD) $(FORCE) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
Any idea?
- resolving references...
WARNING: Could not fetch remote image: http://micropython.org/resources/LCD160CRv10-persp.jpg [time data 'Thu, 19 Jan 2017 09:15:15 GMT' does not match format '%a, %d %b %Y %H:%M:%S %Z']
WARNING: Could not fetch remote image: http://micropython.org/resources/pybv11 ... -800px.jpg [time data 'Tue, 12 Mar 2019 04:56:58 GMT' does not match format '%a, %d %b %Y %H:%M:%S %Z']
WARNING: Could not fetch remote image: http://micropython.org/resources/LCD160 ... itions.jpg [time data 'Fri, 03 Feb 2017 01:13:10 GMT' does not match format '%a, %d %b %Y %H:%M:%S %Z']
done
writing... done
copying images... [100%] https://raw.githubusercontent.com/wipy/ ... PinOUT.png
copying TeX support files... copying TeX support files...
done
build finished with problems, 3 warnings.
make: *** [Makefile:128: latexpdf] Error 1
- Makefile:
latexpdf: cpydiff
@echo "Running LaTeX files through pdflatex..."
$(MAKE) -C $(BUILDDIR)/latex all-pdf
@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
Any idea?
I'm a beginner with this stuff and no programmer at all.
I don't think this route is particularly well tested, as PDF docs via LaTeX are a completely separate and complex workflow.
At the very least, latexmk is required to get the make process to even begin. This isn't in the docs/README.md
I get a completely different kind of error in the build process where pdflatex is failing to handle UTF-8 characters, starting with the line:
This is odd, as sphinx is putting \usepackage[utf8]{inputenc} in the document. xelatex builds the document (with lots of warnings) but doesn't render the Ωs. I end up with a 350+ page PDF with some ropey paragraph layouts.
I used to be a TeX guy, but that was a very long time ago.
When buffering is enabled the DAC pin can drive loads down to 5KΩ.
@hcet14 Out of interest why do you want this? You could build a local HTML image which provides all the docs during an internet outage. That build process always seems to run smoothly.
@scruss I tried your suggestion with latexmk, no difference. Thanks anyway.
I also tried pdftex MicroPython.tex since I get a tex file. But also no output file.
@pythoncoder I prefer pdfs for reading. make html runs smooth here without errors. As I stated above, I'm a complete linux beginner and have no clue about latex. Maybe I can learn something
I suspect this will be harder than it looks. Every tool I know about (Calibre, weasyprint, wkhtmltopdf, pandoc) failed to make a PDF from the source HTML. The document sources need to be fixed by the authors so that "make pdf" will work.
"make epub" works if you want a static, pageable document file.
The core team are aware of the failures but haven't been able to resolve the issue (something to do with missing font characters?). If anyone can help out a PR would be very welcome!
I think I've worked it out … please see PR #6779 Enable PDF doc generation
It requires an absolutely gargantuan TeX Live¹ download to get the correct fonts. For those who just want to see the current manual, here's a link to download one I just generated: MicroPython.pdf.
¹: I knew the late Sebastian Rahtz, the founder of the TeX Live project, when I was a UK TeX User Group board member. The first version fit a full TeX distribution for Windows, Mac OS and most Unix/Linux systems on a single CD-ROM, and it's fair to say that TeX Live has kept the system alive and useful. To build the MicroPython manual I had to download more than a CD-ROM full of just fonts for TeX Live. I'm not sure if Seb would be amused or horrified …
