hello, pythonner and micropythonner.
i want to compile micropython for this proc STM32H750 who is on MCUDev DevEBox.
i have found a complied micropython for this board but i want to compile it myself to update version.
i can compile all stm32 board with almost no problem
but for this board i have this error:
firmware.elf section `.eth_buffers' will not fit in region `RAM_D2'
someone have see this?
i new in micropython, but not in python and not in microcontroleur.
thanck you for your help.
[STM32H750VBT6 ] firmware.elf section `.eth_buffers' will not fit in region `RAM_D2'
Re: [STM32H750VBT6 ] firmware.elf section `.eth_buffers' will not fit in region `RAM_D2'
Which board definition are you using? Can you link to a github repo? I don't think we have an H750 board definition in the main repo.Le fond du garage wrote: ↑Mon Dec 21, 2020 6:52 pmi want to compile micropython for this proc STM32H750 who is on MCUDev DevEBox.
If you're not using ethernet, then I'd suggest disabling the ethernet driver (by removing all `MICROPY_HW_ETH_*` defines from mpconfigboard.h)Le fond du garage wrote: ↑Mon Dec 21, 2020 6:52 pmfirmware.elf section `.eth_buffers' will not fit in region `RAM_D2'
