DHT Library for ESP
PLUB
DHT Library for ESP
Post by PLUB » Thu Jan 21, 2021 7:43 pm
I am using Micropython on an ESP32 and want to understand how add-on libraries work.
I started with the HD44780 library, and now I'm trying the DHT11 / 22 library. I found several but they are either for Raspberry, or for Cpython, or others but not for ESP. In short, I can't do the conversion with the hardware commands.
Do you know where can I find one?
Thank you in advance
eydam-prototyping
Re: DHT Library for ESP
Post by eydam-prototyping » Fri Jan 22, 2021 4:57 pm
There is a DHT driver already integrated in MicroPython:
http://docs.micropython.org/en/latest/e ... dht-driver
Does this answer your question?
PLUB
Post by PLUB » Fri Jan 22, 2021 6:56 pm
Yes I know there is a pilot but what I want is to understand how it works. Is there a DHT.py for ESP?
Regards.
rpr
Post by rpr » Sat Jan 23, 2021 7:26 am
Do you want to use dht on an esp32?
OR
Do you want to know the details of how the dht module works?
https://github.com/micropython/micropyt ... rivers/dht
PLUB
Post by PLUB » Sat Jan 23, 2021 9:50 am
thank you for your reply. The Github https://github.com/micropython/micropyt ... rivers/dht matches my request but it's written in C. I'm looking for something like https://github.com/garyns/ pigpio-dht / blob / master / lib / pigpio_dht / dhtxx.py, adapted to ESP32.
Regards
rpr
Post by rpr » Sat Jan 23, 2021 6:03 pm
Now I understand. It looks like you want a driver written completely in micropython. Maybe one exists but I'm guessing that probably not since the C built in driver already exists. Maybe someone has written it in python as purely an academic exercise.
Post by Roberthh » Sat Jan 23, 2021 7:38 pm
@PLUB: Most likely it won't work. Reading the DHT11/22, the code must tell the difference between pulses ~20 and ~60 µs long. The micropython code uses C for that purpose. A similar code for pycom devices uses the RMT unit for that task. The esp32 is notorious for skews in timing. So using a python code with polling will not result in the required resolution due to interrupts that may happen. Using interrupts like in the code you cited will also not work, due to the very long and varying interrupt latency of the micropython + esp32 combo.
If you want to try anyhow. I have encloses the code used for Pycom devices once. The critical call is pycom.pulses_get(), which returns a list of (level, duration) pairs, with duration give in µs. That would have to be re-modeled by a call, polling the pin and collecting the times.
import pycom
class DHTResult:
    'DHT sensor result returned by DHT.read() method'
    ERR_NO_ERROR = 0
    ERR_MISSING_DATA = 1
    ERR_CRC = 2
    error_code = ERR_NO_ERROR
    temperature = -1
    humidity = -1
    def __init__(self, error_code, temperature, humidity):
        self.error_code = error_code
        self.temperature = temperature
        self.humidity = humidity
    def is_valid(self):
        return self.error_code == DHTResult.ERR_NO_ERROR
class DHT:
    'DHT sensor (dht11, dht21,dht22) reader class for Pycom'
    __dhttype = 0
    def __init__(self, pin, sensor=0):
        self.__pin = pin
        self.__dhttype = sensor
        self.__pin(1)
        time.sleep(1.0)
    def read(self):
        # pull down to low
        self.__send_and_sleep(0, 0.019)
        data = pycom.pulses_get(self.__pin, 100)
        self.__pin.init(Pin.OPEN_DRAIN)
        self.__pin(1)
        bits = []
        for a,b in data:
                if a ==1 and 18 <= b <= 28:
                        bits.append(0)
                if a ==1 and 65 <= b <= 75:
                        bits.append(1)
        if len(bits) != 40:
            return DTHResult(DTHResult.ERR_MISSING_DATA, 0, 0)
        # we have the bits, calculate bytes
        the_bytes = self.__bits_to_bytes(bits)
        # calculate checksum and check
        checksum = self.__calculate_checksum(the_bytes)
        if the_bytes[4] != checksum:
            return DTHResult(DTHResult.ERR_CRC, 0, 0)
        # ok, we have valid data, return it
        [int_rh, dec_rh, int_t, dec_t, csum] = the_bytes
        if self.__dhttype==0:           #dht11
            rh = int_rh                 #dht11 20% ~ 90%
            t = int_t   #dht11 0..50°C
        else:                   #dht21,dht22
            rh = ((int_rh * 256) + dec_rh)/10
            t = (((int_t & 0x7F) * 256) + dec_t)/10
            if (int_t & 0x80) != 0:
                t = -t
        return DTHResult(DTHResult.ERR_NO_ERROR, t, rh)
    def __send_and_sleep(self, output, mysleep):
        self.__pin(output)
        time.sleep(mysleep)
    def __bits_to_bytes(self, bits):
        the_bytes = []
        byte = 0
        for i in range(0, len(bits)):
            byte <<= 1
            if (bits[i]):
                byte |= 1
            if ((i % 8) == 7):
                the_bytes.append(byte)
                byte = 0
        return the_bytes
    def __calculate_checksum(self, the_bytes):
        return the_bytes[0] + the_bytes[1] + the_bytes[2] + the_bytes[3] & 255
PLUB
Post by PLUB » Sun Jan 24, 2021 9:06 am
Thank you for your answers.
I'll see if the RMT module can help me move forward.
On the other hand if someone has an idea to build a routine equivalent to pycom.pulses_get (), I am interested.
Regards
Post by Roberthh » Sun Jan 24, 2021 7:17 pm
Just to prove that I'm wrong, here is the variant of my first code using polling. Seems to work fine. It assumes a clock frequency of 160 MHz. At other frequencies the duration of 0 and 1 bits have to be aligned.
from machine import Pin, disable_irq, enable_irq
class DTHResult:
    ERR_NO_ERROR = 0
    ERR_CRC = 2
    temperature = -1
    humidity = -1
    def __init__(self, error_code, temperature, humidity, dew_point):
        self.dew_point = dew_point
    def is_valid(self):
        return self.error_code == DTHResult.ERR_NO_ERROR
class DTH:
    __dhttype = 0
    def __init__(self, pin, sensor=1):
        self.__pin_obj = Pin(pin, mode=Pin.OPEN_DRAIN)
        self.__pin = pin
        self.__pin_obj(1)
        time.sleep(1.0)
        self.buffer = bytearray(1024)
    def dew_point(self, temp, humid):
        import math
        Compute the dew point temperature for the current Temperature
        and Humidity measured pair
        h = ((math.log(humid, 10) - 2) / 0.4343 +
                (17.62 * temp) / (243.12 + temp))
        dew_p = 243.12 * h / (17.62 - h)
        return dew_p
    @micropython.native
    def pulses_get(self, pin):
        # start the reading
        pin(0)
        time.sleep_ms(19)
        state = disable_irq()
        pin(1)
        for _ in range(1024):
            self.buffer[_] = pin()
        enable_irq(state)
    def read(self):
        self.pulses_get(self.__pin_obj)
        state = self.buffer[0]
        pos = 0
        bits = []
            if state != self.buffer[_]:
                bl = _ - pos
                if state == 1 and 2 <= bl < 7:
                        bits.append(0)
                if state == 1 and 8 <= bl <= 15:
                        bits.append(1)
                pos = _
                state = self.buffer[_]
        if len(bits) != 40:
        if self.__dhttype == 0:         # dht11
            rh = int_rh                 # dht11 20% ~ 90%
            t = int_t   # dht11 0..50°C
        else:           # dht21,dht22
                t = -t
        dew_point = self.dew_point(t, rh)
        return DTHResult(DTHResult.ERR_NO_ERROR, t, rh, dew_point)
        the_bytes = []
        byte = 0
            byte <<= 1
            if (bits[i]):
                byte |= 1
            if ((i % 8) == 7):
                byte = 0
        return the_bytes
        return (the_bytes[0] + the_bytes[1] + the_bytes[2] + the_bytes[3]) & 255
th = DTH(4, 1)
def run():
    time.sleep(0.5)
    result = th.read()
    if result.is_valid():
        print("Humidity: %.1f %%" % result.humidity)
        print("Temperature: %.1f C" % result.temperature)
        print("Dew Point: %.1f C" % result.dew_point)
run()
