import array
import rp2
import random
import select
import sys
import utime
import _thread
from sys import stdin, exit
from _thread import start_new_thread
from utime import sleep
# Configure the number of WS2812 LEDs.
NUM_LEDS = 60
PIN_NUM = 6
brightness = 0.2 # <<< Any value between 0.0 and 1.0
version = "PicoLED V1.00 enter R,G,B or S to run sparkle on core 1"
# global variables to share between both threads/processors
terminateThread = False
@rp2.asm_pio(sideset_init=rp2.PIO.OUT_LOW, out_shiftdir=rp2.PIO.SHIFT_LEFT, autopull=True, pull_thresh=24)
def ws2812():
T1 = 2
T2 = 5
T3 = 3
wrap_target()
label("bitloop")
out(x, 1) .side(0) [T3 - 1]
jmp(not_x, "do_zero") .side(1) [T1 - 1]
jmp("bitloop") .side(1) [T2 - 1]
label("do_zero")
nop() .side(0) [T2 - 1]
wrap()
# Create the StateMachine with the ws2812 program, outputting on pin
sm = rp2.StateMachine(0, ws2812, freq=8_000_000, sideset_base=Pin(PIN_NUM))
# Start the StateMachine, it will wait for data on its FIFO.
sm.active(1)
# Display a pattern on the LEDs via an array of LED RGB values.
ar = array.array("I", [0 for _ in range(NUM_LEDS)])
def pixels_show():
dimmer_ar = array.array("I", [0 for _ in range(NUM_LEDS)])
for i,c in enumerate(ar):
r = int(((c >> 8) & 0xFF) * brightness)
g = int(((c >> 16) & 0xFF) * brightness)
b = int((c & 0xFF) * brightness)
dimmer_ar[i] = (g<<16) + (r<<8) + b
sm.put(dimmer_ar, 8)
time.sleep_ms(10)
def pixels_set(i, color):
ar[i] = (color[1]<<16) + (color[0]<<8) + color[2]
def pixels_fill(color):
for i in range(len(ar)):
pixels_show()
BLACK = (0, 0, 0)
RED = (255, 0, 0)
ORANGE = (255, 150, 0)
YELLOW = (255, 240, 0)
GREEN = (0, 255, 0)
CYAN = (0, 255, 255)
BLUE = (0, 0, 255)
PURPLE = (180, 0, 255)
WHITE = (255, 255, 255)
COL1 = (255, 124, 23)
COLORS = (BLACK, RED, ORANGE, YELLOW, GREEN, CYAN, BLUE, PURPLE, WHITE)
def ModeSparkle(wait_ms):
global terminateThread
count=1
for i in range(NUM_LEDS):
if terminateThread == True:
print("Ending ModeSparkle")
return
r = random.randint(0,255)
g = random.randint(0,255)
b = random.randint(0,255)
rgb = [r,g,b]
pixels_set(i, rgb) # line 109
pixels_show()
print ("Sparkle ", count)
count=count+1
time.sleep_ms(wait_ms)
print(version)
buffLine = input(":").lower()
# Static colours
if (buffLine == "?"):
print(version)
if (buffLine.startswith("r")):
terminateThread = True
pixels_fill(RED)
if (buffLine.startswith("g")):
pixels_fill(GREEN)
if (buffLine.startswith("b")):
pixels_fill(BLUE)
if (buffLine.startswith("k")):
pixels_fill(BLACK)
if (buffLine.startswith("w")):
pixels_fill(WHITE)
if (buffLine.startswith("s")):
time.sleep_ms(100)
lastthread = _thread.start_new_thread(ModeSparkle, (500,))
except:
print("Error starting thread")
except KeyboardInterrupt:
print("Ctrl+C")
terminateThread = True #terminate thread
print("Program END")
