Driver for SH1122 oled display
fdufnews
Post by fdufnews » Tue Feb 09, 2021 4:50 pm
I have made a driver for an oled display based on the SH1122 driver. This display is more expensive than the usual 128x32 one but it offers a 256 x 64 graphic plane with 16 levels of grey.
The driver is based on the ssd1306 one so it has a similar interface.
The driver sh1122.py
# MicroPython SH1122 OLED driver, SPI interface
from micropython import const
import framebuf
# register definitions
SET_COL_ADR_LSB = const(0X0)
SET_COL_ADR_MSB = const(0X10)
SET_DISP_START_LINE = const(0X40)
SET_CONTRAST = const(0X81)
SET_SEG_REMAP = const(0XA0)
SET_ENTIRE_ON = const(0XA4)
SET_NORM_INV = const(0XA6)
SET_MUX_RATIO = const(0XA8)
SET_CTRL_DCDC = const(0XAD)
SET_DISP = const(0XAE)
SET_ROW_ADR = const(0XB0)
SET_COM_OUT_DIR = const(0XC0)
SET_DISP_OFFSET = const(0XD3)
SET_DISP_CLK_DIV = const(0XD5)
SET_PRECHARGE = const(0xD9)
SET_VCOM_DESEL = const(0xDB)
SET_VSEG_LEVEL = const(0XDC)
SET_DISCHARGE_LEVEL = const(0X30)
# Subclassing FrameBuffer provides support for graphics primitives
# http://docs.micropython.org/en/latest/pyboard/library/framebuf.html
class SH1122(framebuf.FrameBuffer):
    @staticmethod
    def rgb(r, g, b):
        return int(max(r,g,b))  # perhaps not the better but .....
    def __init__(self, width, height):
        self.width = width
        self.height = height
        self.pages = self.height // 2
        self.buffer = bytearray(self.pages * self.width)
        super().__init__(self.buffer, self.width, self.height, framebuf.GS4_HMSB)
        self.init_display()
    def init_display(self):
        for cmd in (
            SET_DISP | 0x00,  # off
            # address setting
            SET_COL_ADR_LSB,
            SET_COL_ADR_MSB,  # horizontal
            # resolution and layout
            SET_DISP_START_LINE | 0x00,
            SET_SEG_REMAP,
            SET_MUX_RATIO,
            self.height - 1,
            SET_COM_OUT_DIR,  # scan from COM0 to COM[N]
            SET_DISP_OFFSET,
            0x00,
            # display
            SET_CONTRAST,
            0x80,  # median
            SET_ENTIRE_ON,  # output follows RAM contents
            SET_NORM_INV,  # not inverted
            SET_DISP | 0x01,
        ):  # on
            self.write_cmd(cmd)
        self.fill(0)
        self.show()
    def poweroff(self):
        self.write_cmd(SET_DISP | 0x00)
    def poweron(self):
        self.write_cmd(SET_DISP | 0x01)
    def contrast(self, contrast):
        self.write_cmd(SET_CONTRAST)
        self.write_cmd(contrast)
    def invert(self, invert):
        self.write_cmd(SET_NORM_INV | (invert & 1))
    def show(self):
        self.write_cmd(SET_COL_ADR_LSB)
        self.write_cmd(SET_COL_ADR_MSB)
        self.write_cmd(SET_ROW_ADR)
        self.write_data(self.buffer)
class SH1122_SPI(SH1122):
    def __init__(self, width, height, spi, dc, res, cs):
        self.rate = 10 * 1024 * 1024
        dc.init(dc.OUT, value=0)
        res.init(res.OUT, value=0)
        cs.init(cs.OUT, value=1)
        self.spi = spi
        self.dc = dc
        self.res = res
        self.cs = cs
        self.res(1)
        time.sleep_ms(1)
        self.res(0)
        time.sleep_ms(10)
        self.res(1)
        super().__init__(width, height)
    def write_cmd(self, cmd):
        self.spi.init(baudrate=self.rate, polarity=0, phase=0)
        self.cs(1)
        self.dc(0)
        self.cs(0)
        self.spi.write(bytearray([cmd]))
        self.cs(1)
    def write_data(self, buf):
        self.cs(1)
        self.dc(1)
        self.cs(0)
        self.spi.write(buf)
        self.cs(1)
A small test script
# Display Image & text on SPI driven sh1122 OLED display
from sh1122 import SH1122_SPI
import framebuf
WIDTH  = 256                                            # oled display width
HEIGHT = 64                                             # oled display height
spi = SPI(0)                                            # Init I2C using I2C0 defaults, SCL=Pin(GP6), MOSI=Pin(GP7), freq=1MHz
dc = Pin(4, Pin.OUT)
dc.value(0)
res = Pin(3, Pin.OUT)
res.value(1)
cs = Pin(5, Pin.OUT)
cs.value(1)
oled = SH1122_SPI(WIDTH, HEIGHT, spi, dc, res, cs)                  # Init oled display
# Raspberry Pi logo as 32x40 bytearray 16 levels of gray
buffer = bytearray(b"\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x11\x45\x56\x41\x00\x00\x00\x00\x14\x55\x54\x11\x00\x00\x00\x16\x8A\xAA\xAA\xAA\x73\x00\x00\x36\x9A\xAA\xAA\xA9\x61\x00\x00\x18\xAA\xAA\xAA\xAA\xAA\x30\x02\xAA\xAA\xAA\xAA\xAA\x91\x00\x00\x18\xAA\x97\x8A\xAA\xAA\x80\x07\xAA\xAA\xA8\x79\xAA\x91\x00\x00\x07\xAA\xAA\x85\x7A\xAA\xA1\x0A\xAA\xA8\x58\xAA\xAA\x70\x00\x00\x03\xAA\xAA\xAA\x63\x9A\xA1\x0A\xA9\x45\xAA\xAA\xAA\x30\x00\x00\x00\x6A\xAA\xAA\xA8\x27\x40\x03\x72\x8A\xAA\xAA\xA7\x00\x00\x00\x00\x28\xAA\xAA\xAA\x91\x00\x00\x08\xAA\xAA\xAA\x83\x00\x00\x00\x00\x03\x8A\xAA\xAA\x70\x00\x00\x06\xAA\xAA\xA8\x30\x00\x00\x00\x00\x00\x15\x8A\x95\x00\x00\x00\x00\x59\xA9\x52\x00\x00\x00\x00\x00\x00\x00\x11\x00\x00\x34\x43\x10\x00\x11\x00\x00\x00\x00\x00\x00\x00\x02\x55\x51\x26\x66\x66\x62\x05\x54\x20\x00\x00\x00\x00\x00\x00\x46\x66\x30\x66\x66\x66\x66\x12\x66\x65\x00\x00\x00\x00\x00\x03\x66\x63\x00\x46\x66\x66\x66\x10\x26\x66\x40\x00\x00\x00\x00\x06\x66\x20\x00\x03\x56\x66\x41\x00\x02\x66\x61\x00\x00\x00\x00\x16\x51\x01\x23\x20\x00\x00\x13\x54\x20\x15\x62\x00\x00\x00\x00\x13\x00\x36\x66\x65\x10\x01\x66\x66\x65\x00\x32\x00\x00\x00\x00\x00\x02\x66\x66\x66\x50\x04\x66\x66\x66\x40\x00\x00\x00\x00\x03\x40\x06\x66\x66\x66\x61\x06\x66\x66\x66\x62\x05\x40\x00\x00\x36\x60\x26\x66\x66\x66\x61\x06\x66\x66\x66\x64\x06\x64\x00\x00\x66\x61\x36\x66\x66\x66\x60\x05\x66\x66\x66\x64\x16\x66\x10\x02\x66\x60\x36\x66\x66\x66\x40\x02\x66\x66\x66\x64\x06\x66\x20\x02\x66\x50\x16\x66\x66\x66\x10\x00\x46\x66\x66\x61\x05\x66\x20\x01\x66\x40\x03\x66\x66\x51\x01\x10\x04\x66\x66\x30\x04\x66\x10\x00\x56\x20\x00\x13\x32\x03\x66\x66\x30\x12\x21\x00\x02\x65\x00\x00\x14\x00\x00\x00\x00\x46\x66\x66\x65\x00\x00\x02\x31\x31\x00\x00\x00\x36\x52\x00\x01\x66\x66\x66\x66\x20\x01\x56\x64\x00\x00\x00\x00\x66\x66\x30\x03\x66\x66\x66\x66\x40\x15\x66\x66\x00\x00\x00\x00\x66\x66\x63\x03\x66\x66\x66\x66\x40\x56\x66\x66\x00\x00\x00\x00\x56\x66\x66\x11\x66\x66\x66\x66\x22\x66\x66\x65\x00\x00\x00\x00\x36\x66\x66\x30\x46\x66\x66\x65\x04\x66\x66\x64\x00\x00\x00\x00\x05\x66\x66\x40\x03\x66\x66\x30\x05\x66\x66\x51\x00\x00\x00\x00\x01\x56\x66\x40\x00\x01\x10\x00\x05\x66\x65\x10\x00\x00\x00\x00\x00\x02\x33\x10\x01\x23\x32\x10\x02\x44\x30\x00\x00\x00\x00\x00\x00\x00\x00\x00\x46\x66\x66\x65\x20\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x66\x66\x66\x66\x20\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x26\x66\x66\x62\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x34\x43\x10\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00")
# Load the raspberry pi logo into the framebuffer (the image is 32x40)
fb = framebuf.FrameBuffer(buffer, 32, 40, framebuf.GS4_HMSB)
# Clear the oled display in case it has junk on it.
oled.fill(0)
# Blit the image from the framebuffer to the oled display
oled.blit(fb, 112, 0)
# Add some text
oled.text("Raspberry Pi", 5, 5, 15)
oled.text("Pico", 5, 15, 15)
if (HEIGHT > 32):
    oled.text("This display", 5, 25, 12)
    oled.text("has more than", 5, 35, 8)
    oled.text(" 32 lines", 5, 45, 4)
if (WIDTH > 128):
    oled.text("This display", 149, 25, 12)
    oled.text("has more than", 149, 35, 8)
    oled.text(" 128 pixels", 149, 45, 4)
# Add a color scale
for i in range(0,16):
    oled.fill_rect(i*8, 55, 8, 8,15-i)
    oled.fill_rect(247-(i*8), 55, 8, 8,15-i)
# Finally update the oled display so the image & text is displayed
oled.show()
It is not clear on the picture but the Raspeberry Pi logo is in level of grey
fdufnews
Re: Driver for SH1122 oled display
Post by fdufnews » Sun May 16, 2021 8:14 am
I have created a repo on github to store some example code for the Pico
The driver for the SH1122 is in the drivers directory.
In the examples/sequence directory there are 2 short pieces of code that display animations using the SH1122. There is a short video in the horsejump subdirectory.
Post by pythoncoder » Mon May 17, 2021 7:10 am
Nice. ;)
I'm puzzled as to why, in the photo, your test script doesn't display the text "This display has more than 128 pixels".
fdufnews
Post by fdufnews » Mon May 17, 2021 11:38 am
The test script has evolved since I took the photo.
Here's an uptodate one
Mark's Bench
Post by Mark's Bench » Wed May 19, 2021 12:19 am
That looks great - thank you for posting it! I have an SH1122 in a box somewhere - could never get it to work right so I put it in a "safe place". Once I find it I'll give it a shot with your driver.
fdufnews
Post by fdufnews » Wed May 19, 2021 7:14 am
It's a pretty good display. I just warn you that displaying static images for a long time leaves marks.
