PIO @asm_pio decorator out_init=() limit of 8 gpio
thetestdoctor
Post by thetestdoctor » Sat Feb 27, 2021 12:01 am
I am trying set 10 gpio pins using the PIO, with a base pin of 6, gpio 6-15 should be set to low using the code below.
The 2 highest gpio pins (14 & 15) are not driven & float high (checked on a scope). I have tried another Pico & moving
the base bin with the same results, the upper 2 pins don't get driven. The code re-written in C works fine.
Am I missing something here or is there a limit in Micropython of 8 pins in the asm_pio decorator out_init=().
Many thanks.
from rp2 import PIO, StateMachine, asm_pio
@asm_pio(out_init=(PIO.OUT_LOW, PIO.OUT_LOW, PIO.OUT_LOW, PIO.OUT_LOW,
                   PIO.OUT_LOW, PIO.OUT_LOW),
         out_shiftdir=PIO.SHIFT_RIGHT, autopull=True, pull_thresh=10)
def limited():
    out(pins, 10)
sm1 = StateMachine(1, limited, freq=1000, out_base=Pin(6))
sm1.active(1)
sm1.put(0x00)
Re: PIO @asm_pio decorator out_init=() limit of 8 gpio
Post by Roberthh » Sat Feb 27, 2021 6:49 am
I stubled over that too a few day ago. See https://github.com/micropython/micropython/issues/6933 and the PR for fixing the bug: https://github.com/micropython/micropython/pull/6938. I do not know when this will be fixed in the daily builds.
thetestdoctor
Post by thetestdoctor » Sat Feb 27, 2021 1:29 pm
Many Thanks for that, I did think it was a bug. Not a big deal as I am just tinkering about but thought I would mention it in case someone else has the same issue & to push it back so it gets fixed as some point.
