main.py isn't running when Pico connected to external power
I think I'm missing a step somewhere. Can't get Pico to run when it isn't being powered by the micro-USB.
Have a main.py to blink the on board LED. Trying to power it by connected 5 VDC to VSYS. I'm using Thonny with the Micropython interpreter to save the program onto the Pico. Program just doesn't seem to be running at all.
Is there a guide somewhere or a simple tutorial that anybody can link me where the Pico isn't being powered through the USB port? I think I must be missing something
Thanks in advance
Thanks in advance
Re: main.py isn't running when Pico connected to external power
That seems to work fine for me.
I created main.py with the following: and blinky.py with I verified that powering up via USB worked. Then I disconnected the USB cable and connected VSYS and GND to a 5V source and the blinky program is running.
import blinky
from machine import Pin, Timer
led = Pin(25, Pin.OUT)
tim = Timer()
def tick(timer):
global led
led.toggle()
tim.init(freq=2.5, mode=Timer.PERIODIC, callback=tick)
Since you are using Thonny: Are you sure that you really copied the main.py file to the board? Just running the files with Thonny dos nto copy it permanently to the boards file system.
I used rshell to copy files onto Pico MicroPython flash filesystem (cp main.py /pyboard).
Today I copied boot.py and main.py, and both get executed, on powering as well as on soft reboot:
https://www.raspberrypi.org/forums/view ... 3#p1830113
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
webrepl_client.py
At the moment I'm doing;
Save As --> Raspberry Pi Pico --> "main.py", save
Is that correct?
- aivarannamaa
This should do.
Does it start running again when you reconnect USB? Can it be powering issue?
Aivar Annamaa
https://thonny.org
https://thonny.org
Can you post your main.py?
Are you sure, you are not missing any import or pin setting in your software?
i have faced the same problem as ssfel. Unfortunately none of the suggestions has been helpful.
At least for my application I found a workaround:
I start main.py as usual having the pico connected via an USB cable. Then connect an external 5V source to VSYS. Now I can unplug the USB connection and the pico continues to run.
Any better solution is still welcome.
As @roberthh did suggest:
Don't trust thonny or any fancy, colorful gui.
Verify that main.py is really on the device using pyshell or the like. You can also check with a small uPy program whether main.py is really where it belongs (next to boot.py).
A few hours of debugging might save you from minutes of reading the documentation!
