UART won't send all MIDI control messages [solved]
Grumpy_Mike
Post by Grumpy_Mike » Sat Mar 06, 2021 7:21 am
I am trying to send some MIDI messages through the UART. I am finding that every message above 0xB0 produces nothing on the output as seen by the MIDI monitor app on a Mac.
This is the code I am using:-
MicroPython code to write from UART1 on the Pico
sends some MIDI messages
ser = UART(1, 31250, tx=Pin(8), rx=None) # no recieve
# send control message - works OK
ser.write(chr(0xB0))
ser.write(chr(0x00)) # write bank select msb
ser.write(chr(0x00)) # set to a zero
# send a program change message - produces nothing
ser.write(chr(0xC0))
ser.write(chr(27))
# ask for retune - produces nothing
ser.write(chr(0xF8))
Is there something wrong with me using chr(), if so how do you send defined bytes?
Other messages like note on and note off work this way.
Re: UART won't send all MIDI control messages
Post by Roberthh » Sat Mar 06, 2021 7:24 am
why not using ser.write(b'\xC0'))? That avoids problems with encoding.
Grumpy_Mike
Post by Grumpy_Mike » Sat Mar 06, 2021 7:35 am
So it does thanks. I am not too familiar with python sending bytes that has always worked on "grown up" python.
How would you cope with oring a variable into that?
like
ser.write(chr(0xC0 | channel ))
Thanks again.
Post by Roberthh » Sat Mar 06, 2021 9:03 am
In that case it's better to define a bytearray for the command, in which you can assign the values as integers
cmd = bytearray(cmdsize)
cmd[0] = 0xd0 | channel # set the first byte
# set more bytes as required
uart.write(cmd)
Grumpy_Mike
Re: UART won't send all MIDI control messages [solved]
Post by Grumpy_Mike » Sat Mar 06, 2021 10:12 am
Excellent, works like a charm.
Many thanks. :)
