Missing pyb, serial console and FTP problem.
epninety
Re: Missing pyb, serial console and FTP problem.
Post by epninety » Tue Oct 13, 2015 3:13 pm
No jumpers delivered with my board either. No problem for me, but worth mentioning.
Dave
Theo
Post by Theo » Tue Oct 13, 2015 8:45 pm
danicampora wrote:No need to ship it back. Just PM me your name and I'll send another board to you.
Today I already received the new expander module and my WiPy is running again. Thank you very much Daniel.
JimTal001
Post by JimTal001 » Fri Oct 30, 2015 2:00 pm
Hello danicampora,
Were you able to test WinSCP?
Using WinSCP and FTP, I an not able to completely connect with the following message:
"Error getting name of current remote directory"
"Invalid response to PWD command"
The WinSCP screen shows it connected successfully then after trying to start the session I get the error above. Maybe there is a setting in WinSCP which needs to change, I'll experiment further.
On a better note, I was able to successfully connect with Putty/Telnet.
danicampora
Post by danicampora » Fri Oct 30, 2015 2:15 pm
Is this also happening with the latest build? http://micropython.org/resources/firmwa ... 23a961.zip
Have you limited the number of data connections to 1? Is the FTP mode set to non-secure?
JimTal001
Post by JimTal001 » Fri Oct 30, 2015 2:58 pm
Yes, only Trying to connect with WinSCP, my Telnet connection is closed (if this is what you mean).
It is set to no encryption (if this is what you mean).
Version: Micro Python v1.4.6-21-gff736d6 on 2015-09-27; WiPy with CC3200
lucien2k
Post by lucien2k » Fri Oct 30, 2015 3:10 pm
winscp doesn't work, I tried for a while with that too. I ended up having to download Filezilla instead.
JimTal001
Post by JimTal001 » Fri Oct 30, 2015 7:40 pm
I downloaded Filezilla and am still not able to connect. I get the message:
Status: Connecting to 192.168.1.1:21...
Error: Connection timed out after 20 seconds of inactivity
Error: Could not connect to server
my encryption setting is: "insecure"
any suggestions?
lucien2k
Post by lucien2k » Fri Oct 30, 2015 7:48 pm
Are you connected to the wipy's wireless network?
Can you ping it?
JimTal001
Post by JimTal001 » Fri Oct 30, 2015 7:49 pm
I can connect with putty/telnet and I am connected via the wireless network.
I do NOT have the wipy connected via USB to the PC which is running putty or Filezilla.
And Yes I can ping it successfully via the command prompt wirelessly.
lucien2k
Post by lucien2k » Fri Oct 30, 2015 7:59 pm
I've attached a screenshot of the settings that work for me. It took me a little while to get it sorted (started with winscp, same as you).
